I am trying to steup the Partial CLI on my work machine that is very tied down security wise. We have to use a proxy server that requires and user name and password.
I finally managed to get Node.js installed, but now I can not get the particle cli to run. If I type
Particle login I get these errors
particle: Adding dependencies…
! Get https://binaries.particle.io/node/v5.4.1/win-x64/node.exe: dial tcp 52.85.183.40:443: i/o timeout
done
particle: Installing plugins…
! exec: “C:\Users\e742033\AppData\Local\particle\node-v5.4.1-windows-x64\bin\node.exe”: file does not exist
particle: Installing plugins (retrying)…
! Error installing package.
! Try running again with GODE_DEBUG=info to see more output.
I am assuming that first get of node.exe is the issue. Is there any way I can configure a proxy server for the particle application or does it use the same proxy settings as npm?
