Particle CLI cant load Firmware Binary - Electron
I have downloaded the binary, but cannot upload to Elektron.
Basically I have the same problem as here Particle CLI cant load Firmware Binary - Electron - AT&T data card [Solved], except reinstalling nodejs and particle cli does NOT solve the problem.
So I downloaded the firmware binary and trying to flash it to Elektron via USB using Linux Mint and particle cli.
myuser@laptop ~/Documents/Particle $ nodejs --version
v0.10.37
myuser@laptop ~/Documents/Particle $ particle --version
1.11.0
myuser@laptop ~/Documents/Particle $ particle identify
Your device id is myDeviceID
Your IMEI is myIMEI
Your ICCID is myICCID
Your system firmware version is 0.4.8
myuser@laptop ~/Documents/Particle $ particle flash --serial blink.bin
! PROTIP: Hold the SETUP button on your device until it blinks blue!
? Press ENTER when your device is blinking BLUE
sending file: blink.bin
! serial:
Error writing firmware...TypeError: Cannot call method 'copy' of undefined
    at Function.Buffer.concat (buffer.js:499:9)
    at Object.YModem._sendPacket (/usr/lib/node_modules/particle-cli/lib/ymodem.js:179:20)
    at Object.YModem._sendFileHeader (/usr/lib/node_modules/particle-cli/lib/ymodem.js:173:15)
    at start (/usr/lib/node_modules/particle-cli/lib/ymodem.js:147:17)
    at runTask (/usr/lib/node_modules/particle-cli/node_modules/when/pipeline.js:37:16)
    at /usr/lib/node_modules/particle-cli/node_modules/when/pipeline.js:42:12
    at tryCatchResolve (/usr/lib/node_modules/particle-cli/node_modules/when/lib/apply.js:46:23)
    at callAndResolve (/usr/lib/node_modules/particle-cli/node_modules/when/lib/apply.js:30:12)
    at callAndResolveNext (/usr/lib/node_modules/particle-cli/node_modules/when/lib/apply.js:40:4)
    at tryCatchReject3 (/usr/lib/node_modules/particle-cli/node_modules/when/lib/makePromise.js:856:7)
What I am doing wrong?
What NodeJS / particle cli version am I supposed to be using?
After upgrade nodejs to v0.10.43, the latest in the 0.10.x series the issue is still there.
v0.10.43 is rather old by now. 0.12.7 is old already which used to work just fine. I believe node is at 5.7.1 by now, which would be worthwhile trying?
Thanks, you were right. After a few trials I finally suceeded with node v5.7.1;
Flash success!
Aborted
ps.: also tried the 0.12.x series, no luck there either.
