Particle CLI cant load Firmware Binary - Electron - AT&T data card [Solved]
I can download the Binary but cannot seem to get it into the Electron.
I go from Blinking Blue to solid Blue LED back to Blinking Blue with this error:
Your device id is myDeviceID
Your IMEI is myIMEI
Your ICCID is myICCID
Your system firmware version is 0.4.8
MacBook-Pro-2:desktop bulldoglowell$ particle flash --serial firmware.bin
! PROTIP: Hold the SETUP button on your device until it blinks blue!
? Press ENTER when your device is blinking BLUE
sending file: firmware.bin
! serial:
Error writing firmware...TypeError: Cannot call method 'copy' of undefined
    at Function.Buffer.concat (buffer.js:499:9)
    at Object.YModem._sendPacket (/usr/local/lib/node_modules/particle-cli/lib/ymodem.js:179:20)
    at Object.YModem._sendFileHeader (/usr/local/lib/node_modules/particle-cli/lib/ymodem.js:173:15)
    at start (/usr/local/lib/node_modules/particle-cli/lib/ymodem.js:147:17)
    at runTask (/usr/local/lib/node_modules/particle-cli/node_modules/when/pipeline.js:37:16)
    at /usr/local/lib/node_modules/particle-cli/node_modules/when/pipeline.js:42:12
    at tryCatchResolve (/usr/local/lib/node_modules/particle-cli/node_modules/when/lib/apply.js:46:23)
    at callAndResolve (/usr/local/lib/node_modules/particle-cli/node_modules/when/lib/apply.js:30:12)
    at callAndResolveNext (/usr/local/lib/node_modules/particle-cli/node_modules/when/lib/apply.js:40:4)
    at tryCatchReject3 (/usr/local/lib/node_modules/particle-cli/node_modules/when/lib/makePromise.js:856:7)
Have you got the most recent version of CLI?
npm update -g particle-cli
yes, updated.
I can see the device, but I cannot make it flash:
 MacBook-Pro-2:Binaries bulldoglowell$ particle identify
Your device id is 363113433ba5003430050038
Your IMEI is 352260712031622
:confounded:
EDIT: I have both files that downloaded in their own folder whilst I use:
Reinstalled Node.js, updated Particle CLI and it flashed.
What version of node are you using that works? I’m having the same issue, on v0.10.33.
This is way too old.
At one instance a few months back I had to upgrade to somthing higher than 4.0.0
