I have a particle argon that is always stuck blinking blue or green. “particle serial inspect” returns with no errors and “particle serial wifi” doesn’t seem to have any effect even when I put the correct wifi info. I have a second particle argon that works fine so I don’t think it’s a problem with my wifi or me configuring my argon incorrectly. What do I do to troubleshoot this?
Is this really blue or rather cyan?
Can you post a video (min. 30sec)?
It’s the dark blue, not the light blue that blinks when it’s working.
Have you tried Safe Mode?
Can you post the output of particle serial inspect?
Platform: 12 - Argon
Modules
Bootloader module #0 - version 311, main location, 49152 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
System module #1 - version 1301, main location, 671744 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
User module #1 - version 5, main location, 131072 bytes max size
UUID: 72B73BFAB5C902DBE9EC90A13958C90408C6FA4758B9F9C5CFB5100141C1C58B
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
System module #1 - version 326
NCP module #0 - version 5, main location, 1536000 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
I had mine stuck in blinking green due to WiFi connectivity issues after swapping WiFi networks. I resolved it after using the CLI to add the new WiFi network to it. I also had my Xenon’s stuck in blinking green once I fixed the connectivity issues with the Argon. For this I had to go in and create a brand new mesh network, and abandon the old one on all devices. Everything else wouldn’t fix it. While I was trying to join the Xenon’s to the original mesh network it would get stuck in the listening mode, and using the particle app I somehow got out of it, but honestly I don’t know how.
