Optional aspect of 'Device Name or ID' not working in IFTTT
Can the ‘New event published’ recipe be updated so the Device field truly is optional and/or allow picking an All option? Below this field in IFTTT it says “An optional id for a particular device” but I can’t figure out how to not include one, it’s a drop down with all of my devices.
I mainly use IFTTT to send me an email for certain publish events and it’s getting to be a pain to have to set them all up manually. I’d love to able to set a single IFTTT applet to send me an email anytime any device publishes an ‘email’ event, for example.
I tried using the browser dev tools to submit a blank device but got an error
  "original":{
    "type":"error",
    "code":"invalid_parameters",
    "message":"Sorry, there were some problems with your request.",
    "details":[
        "message":"Please select a valid option",
        "parameter":"/stored_fields/~1triggers~1particle.events/core_name"
  "validation_errors":{
    "stored_fields":{
      "/triggers/particle.events":{
        "core_name":[
Not sure if that’s possible, but you should be able to use the IFTTT Maker endpoint with a webhook, that can be triggered by any device.
I ran into this same issue recently when I wanted to use IFTTT to listen for an event generated internally by the Particle Cloud (hook-response). It forces you to choose a device, it’s not optional (even though it says it is).
