I’m trying to use the node-red-contrib-particle-official.
I’m facing a strange behaviour: the very first value sent is kept on the following messages.
What I have already done:
- Created a Particle OAuth client and reported the
Client IDandClient Secretto the Particle Publish node. - Populate properties
eventandpayload. - Subscribed to the same event.
Both the Node-RED debug pane and the Particle console list the same value 0.
When sending the messages from the console, the correct value is received.
Am I doing something wrong with the Node-RED node? Thank you for your help!
- The Node-RED flow
[{"id":"9f2ac2d1.aa9d18","type":"particle-publish","z":"74fa81ef.39a3f","name":"","auth":"e99276df.2a63","scope":"user","product":"","event":"","x":520,"y":160,"wires":[]},{"id":"2211e8fc.d95e9","type":"inject","z":"74fa81ef.39a3f","name":"","props":[{"p":"payload"},{"p":"event","v":"message","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"0","payloadType":"str","x":190,"y":100,"wires":[["9f2ac2d1.aa9d18","5a10778c.04eb1"]]},{"id":"e2a7f909.df0c4","type":"inject","z":"74fa81ef.39a3f","name":"","props":[{"p":"payload"},{"p":"event","v":"message","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1","payloadType":"str","x":190,"y":160,"wires":[["9f2ac2d1.aa9d18","5a10778c.04eb1"]]},{"id":"ea29c7ff.b7f688","type":"particle-subscribe","z":"74fa81ef.39a3f","name":"","auth":"e99276df.2a63","scope":"user","product":"","event":"message","device":"","x":140,"y":280,"wires":[["ac72b4a4.edeed8"]]},{"id":"ac72b4a4.edeed8","type":"debug","z":"74fa81ef.39a3f","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":530,"y":280,"wires":[]},{"id":"5a10778c.04eb1","type":"debug","z":"74fa81ef.39a3f","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":530,"y":100,"wires":[]},{"id":"e99276df.2a63","type":"particle-config","clientId":"messages-1188","clientSecret":"9879ec938690619f94f707b88bfae5992a6c277d"}]
