Newbie, Xenon setup failed
First time user, totally lost. Power to Xenon went off during installing step 1, now it flashes fast yellow, setup on IOS says can’t find device, tried factory reset, still flashing fast yellow. Can’t find forum answers for this, what do I do now? Thanks in advance.
Can you get it to listening mode by pressing the mode button some seconds? Then you should be able to normally set it up.
Third gen devices should be mostly the same, there are several topics on this subject with argons and borons. Here is one: Boron in perpetual DFU mode
Make sure you substitute any boron binaries for xenon.
No, apparently not
Wonderful, that worked. Thanks!
