New xenon setup failure
So I have 1 argon and 2 xenon on a network and trying to setup a new xenon. Things seem normal - loading firmware and the Samsung is up to “sending part 11 to device.” before failing to connect to device. or “setup has encountered an error and cannot continue …” I have gone through the process several times and will usually hang after 4 or more parts, with a “trying to connect to device.” The other argon and 2 xenon devices worked fine but this one xenon is just not happy.
I’m probably doing something stupid… any ideas?
cheers,
-jim
You can try putting the stubborn Xenon into DFU Mode and run particle update.
Thats exactly what I did and it works! went through the setup process again and all went smoothly.
cheers,
-jim
