New Plus Pricing Model data operations and data usage scale
Hello,
I see that the new Plus Pricing model is out of "Coming Soon" and available for upgrade. The model details online indicate scaling to 5M operations and operations are still defined as 622 to 1024 bytes. I'm assuming then that the total cellular data limit is similarly scaled on a Plus block at the same ratio? ie. if 540MB/720k = 750b per operation on average, then 5M * 750b/operation = 3.75G maximum under the Plus plan. Is that correct?
Update:
The explanation page (Migrating to Basic/Plus) has been updated now with the following text:
What is a block?
Billing is measured in blocks.
  • A block includes 720K (basic) or 5M (plus) Data Operations per month.
  • Up to 100 devices per block.
  • Up to 540 MB (basic) of cellular data per month, pooled across all devices.
  • Blocks are US$ 299.00 (basic) or US$ 599.00 (plus) per month per block.
But this still doesn't list the data limit for Plus, only for Basic (540MB).
It also states:
Which products should I move to basic/plus?
  • Any product that will have more than 100 devices in it must be on the basic/plus plan.
  • Any product whose devices use more than 100K data operations, or large amount of cellular data.
The Pricing | Particle page lists only data operations as 1024 byte packets and lists 5M of these under Plus. Can a Particle representative please weigh in and clarify that the Plus plan is ready for migration on projects presently limited by the basic plan's 540MB limit?
