I am unable to finish the setup of any of the devices. Although they breathe cyan, when I follow the steps at setup.particle.io, the final screen will timeout (’‘Your electron failed to connect to the Particle cloud’’)
Probably I’m missing something here, but I’m not sure what.
When trying Particle keys doctor, I receive the following:
Found DFU device 2b04.d00a
New Key created
I couldn't find the file: 31001a000247363334383136_ec_new.der
Make sure your device is in DFU mode (blinking yellow), and that your computer is online.
Error - I couldn't find the file: 31001a000247363334383136_ec_new.der
Where 31001a000247363334383136 is the device id I obtained with particle identify.
I just went into the Build IDE, and manually added my device ID. Then a couple of seconds later it also popped up in my Console, and is now recognized as a Particle Electron.
Very strange to me, how the setup.particle.io didn’t work. But at least I can use my Electron now
