I have the Spark.zip and the Driver does not install. any suggestions? (I did do the suggestions in the other threads, but my Win 7 Professional 64 bit will not accept any of the work arounds that I’ve seen. I’ve tried and got close, but the Driver is not acceptable. I still need help.
There’s some instructions here: http://docs.particle.io/photon/connect/#connecting-your-device-using-windows under INSTALLING THE PARTICLE DRIVER
The current photon driver is unsigned - I will create a signed driver this week.
It took a while to get the Update Driver steps in the correct order with the current USB driver.
I was able to communicate with the Proton and log into my wireless access point and my Proton was updated with new firmware and now the green LED is breathing.
