I am interested in implementing an integration monitoring solution using logic similar to the one described here:
The link included in the documentation to access the source code leads to a Page not Found error (https://github.com/particle-iot/cloud-app-templates/tree/main/apps/integration-monitor)
Is this sample code still available anywhere?
The docs page is currently hidden from navigation as the feature release was postponed. The page does still work if you have the direct URL. However, the Github repo for it was never made public because the feature wasn't released. Checking to see if the Github can be made public now or if it will have to wait.
The docs/src/assets/file link is only two of the files from the actual repo, there are a bunch more that were not copied.
@jon.dev - please open a ticket with us about this, we can help your team directly in this regard.
