Mikroe breakout board compatibility with MSoM 524
Hi Particles, just wondering if anyone has used or can confirm whether the Mikroe Series 3 breakout board (shield) is compatible with the new M-SoM 524 modules from particle. They claim they are compatible with all generation 3 particle devices but only cite the B-SoM devices in their specs - the shield is described here: Click shield for Particle Gen 3
I put an M404 in the shield and it did not boot when powered only by USB. This isn't surprising because of the higher power requirements of the M-SoM. It may work if you have the battery connected but I didn't have a battery with the right connector handy.
Thanks again... I'll order the particle shield to do dev. Shame, I really like some of the Mikroe click board modules
At least with the B524 + Eval board I needed to connect an extra battery to power a small servo.
