Hello
I’ve been strugling to setup a photon, having recently upgraded to OS high sierra. It’s a previously working photon, just haven’t used with this OS.
When usb connected it blinks blue, updated via dfu, particle cli uptaded (after having lots of trouble with npm and permissions)
"MacBook-Pro:~ bernardovalente$ particle serial wifi
? Should I scan for nearby Wi-Fi networks? Yes
? Select the Wi-Fi network with which you wish to connect your device: Vodafone-F6DC5E
? Should I try to auto-detect the wireless security type? No
Attempting to configure Wi-Fi on /dev/tty.usbmodemFD121
? Security Type WPA2
! Something went wrong: Serial timed out
? Security Type WPA
MacBook-Pro:~ bernardovalente$ particle setup
_ __ _ _ _
| '_ \ __ _ _ __| |_(_) ___| | ___
| |_) |/ _` | '__| __| |/ __| |/ _ \
| __/| (_| | | | |_| | (__| | __/
|_| \__,_|_| \__|_|\___|_|\___|
https://particle.io
> Setup is easy! Let's get started...
> It appears as though you are already logged in as bernas_123@hotmail.com
? Would you like to use this account? Yes
! PROTIP: Hold the MODE/SETUP button on your device until it blinks blue!
! PROTIP: Please make sure you are connected to the internet.
> I have detected a Photon connected via USB.
? Would you like to continue with this one? Yes
! The device supports setup via serial.
setting up device 280022001447343339383037
> Obtained magical secure claim code.
Claim code set. Now setting up Wi-Fi
? Select the Wi-Fi network with which you wish to connect your device: xxx
? Should I try to auto-detect the wireless security type? Yes
> Detected WPA(PSK/AES,TKIP/TKIP) WPA2(PSK/AES,TKIP/TKIP) security
Potentially unhandled rejection [3] Serial timed out (WARNING: non-Error used)
Potentially unhandled rejection [4] Serial timed out (WARNING: non-Error used)
MacBook-Pro:~ bernardovalente$ "
it then blinks orange (or red, dont know) several times and restarts blinking blue.
i feel like i’ve done everything i could from whats available in here, could anyone help me?
thank you
EDIT: ps: i cant enter in safe mode, when i press setup+reset i and release reset when blinking magenta, the photon goes fast to white and fast blinking blue. dfu mode is ok. changed cables
