Is there a way to submit documentation corrections?
While reading through the Electron documentation I occasionally notice errors.
E.g. In mode-switching#automatic-mode, it says:
The default mode of the Electron is "automatic mode". This means that the Electron will attempt to connect to Wi-Fi automatically.
I'm assuming the original intent was for it discuss the Cellular connection and not Wi-Fi.
It would be very nice if it was possible to submit corrections to documentation. I've seen cases where documentation was hosted on Github, and then fixes can submitted as Issues or PRs, not sure this is the case in this instance though.
Best,
Or
The Edit button on the top right will let you view the documentation on GitHub and submit a pull request.
Ah, that’d work. Thanks!
Unfortunately, in this case, I’m not sure how to fix the problem as the page is rendered with {device} and WiFi is hard-coded. Ended up opening an issue instead.
