A couple of questions/comments
A few general comments and questions:
  1. It would be very appreciated if the explanations for some of the functions in the Electron documentation were filled in, e.g Electron/FuelGauge and Electron/PMIC.
  2. Would it be possible to get a reference to the source code of Particle.publish? I’m interested in possibly making UDP requests manually and wanted to see what is being done in Particle.publish to make sure I’m following best practices, etc. I tried searching in spark/firmware but to no avail.
  3. I’ve seen it mentioned in the forum that there’s work planned to support gracefully handling voltage dropping below a certain threshold and either going into emergency hibernation or something on that line. Is there any progress on that? I don’t want to commit to anything but I see myself needing that very much and if there’s no work being done at the moment I might try to write a simple library for this.
Best,
Or
