We had an issue literally just start showing up in our classroom today.
In particle workbench, local compile works file. However, when we go to flash, we get the following error:
:::: STARTING FLASH
/bin/sh: c:/Users/ddcio/.vscode/extensions/particle.particle-vscode-core-1.16.17/src/cli/bin/windows/amd64/particle.exe: No such file or directory
make[1]: *** [C:/Users/ddcio/.particle/toolchains/buildscripts/1.15.0/Makefile:167: flash-app] Error 127
make: *** [C:/Users/ddcio/.particle/toolchains/buildscripts/1.15.0/Makefile:111: flash-user] Error 2
* The terminal process "C:\Users\ddcio\.particle\toolchains\buildtools\1.1.1\bin\bash.exe '-c', 'make -f 'C:/Users/ddcio/.particle/toolchains/buildscripts/1.15.0/Makefile' flash-user -s'" terminated with exit code: 2.
* Press any key to close the terminal.
If we go into the target directory and use the particle-cli: particle flash --usb xxx.cpp we can successfully flash.
We are on:
particle cli version: 3.22.0
particle workbench 1.16.18
We just noticed there appears to have been an update to 1.16.18
UPDATE: noticing the path was stuck on 1.16.17,so if I manually place Workbench back to v1.16.17 it seems to work
