First of all, that’s awesome that Particle has released this new tool.
I just installed it and login, compiling are all working fine but facing issues when trying to flash.
It works when using particle flash in the windows console but when I run the task particle: flash application(local) from VS, I have the following the errors.
[EDIT]
As digitalhack mentioned in his answer, the command cp not found was due to the command missing in the folder C:\Users<YourUsername>.particle\toolchains\buildtools\1.0.0\bin. After copying cp.exe from cygwin bin folder to that folder, no more copy errrors. Thanks @digitalhack
This is probably the cause of the error. You appear to be using Windows and cp by default is not a valid command. I’m not a Windows guy so I don’t really know how to fix this.
There is a portion of Cygwin already in the installer. That’s how GNU make is run under Windows. It’s possible that cp wasn’t installed, however, which would explain that error. Or it’s a path issue of some sort.
I ran into the same problem trying to use the Particle: Flash application (local) option. When I checked
C:\Users\<YourUsername>\.particle\toolchains\buildtools\1.0.0\bin I found that the cp.exe file was missing. It appears that the cygwin1.dll is the 64 bit version 2.10.0. I copied over cp.exe from my current 64 bit version of cygwin which is at 2.11.1 and it worked fine.
Hello @jberi
I meant that I could flash the generated binaries after compiling from Workbench by using Windows command line and execute particle flash --serial testTLS.bin.
I’m using Win7.
Hello @digitalhack,
That did the trick for me too, thanks a lot!
cp.exe was missing under .particle\toolchains\buildtools\1.0.0\bin and I copied it from cygwin bin folder to that location and it worked but I still face the other error.
there were no errors below that line but I noticed that the cp.exe binary that I copied was from an old cygwin install 32bits, I copied a 64 bits cygwin cp.exe file and it worked.
Looks like we can only flash when in DFU mode and not in listening mode when use the command line.
Thanks again for the help, I really appreciate it.
