Cloud Flashing from cli works, inside VisualStudio it doesn't
Hey,
So i wanted to flash my electron via cloud. If I use CLI to flash the .bin file it works. But when i call
Particle: Cloud Flash
inside Workbench it wont work. (Local Flash works)
The output in the Workbench is very long, here is the part with the error:
../../../build/module.mk:232: recipe for target 'target/workspace.elf' failed
make[1]: *** [target/workspace.elf] Error 1
make[1]: Leaving directory '/firmware/modules/electron/user-part'
../build/recurse.mk:11: recipe for target 'modules/electron/user-part' failed
make: *** [modules/electron/user-part] Error 2
Flash device failed: Compiler encountered an error
Error: Command failed with exit code 1: c:\Users\PhilippOverath\.vscode\extensions\particle.particle-vscode-core-1.9.0\src\cli\bin\windows\amd64\particle.exe cloud flash Pydro_E2 --target 1.4.4 --no-update-check
Targeting version:  1.4.4
Any ideas?
Btw. I am using two libraries:
Metro.h
Ubidots.h
Could be that it is the libraries?
The interesting bit is not in there tho'
indicates that the actual error has already occured before that during the linker run
Alright,
the whole output is too long to post here (>70k).
For what shall I look in the output. Any special keywords?
Usually the linker output is usually max. a couple of dozend lines up from the line I quoted.
I found the error.
It was some library problem with Adafruit_DHT.h and Adafruit_DHT_particle.h and double definitions. Even if I didn’t have those libraries included in my main file. I then saw that they were defined as dependencies in project.properties, i gues some leftovers from my first testing with the electron.
After removing them from the project.properties list it worked.
