[ISSUE] Cloud Flash Failure
I have been having an issue getting “Particle: Cloud Flash” to work in Workbench. The code I want to flash compiles without error and can flash locally using DFU mode. If I compile the code, I can even flash over the air using the Particle CLI. But, Cloud Flash fails with the very verbose message pasted below.
Here is what I have tried:
  • Reset environment
  • Disabled all VS Code plug-ins except the three Particle ones
  • Updated all including the CLI
  • Cleaned my local firmware and OS
  • Deleted the /target directory and let it be rebuilt on compile
I am running:
  • Mac OS X Ventura 13.1
  • CLI v3.7.0
  • Workbench Core VS Code Plug-In v1.15.10
Here is the error log when the cloud flash fails:
Targeting version: 4.0.2
Including:
    lib/AB1805_RK/src/AB1805_RK.h
    lib/CryptoLW-RK/src/Acorn128.h
    lib/CryptoLW-RK/src/Ascon128.h
    lib/CryptoLW-RK/src/AuthenticatedCipher.h
    lib/CryptoLW-RK/src/BlockCipher.h
    lib/CryptoLW-RK/src/Cipher.h
    lib/CryptoLW-RK/src/Crypto.h
    lib/CryptoLW-RK/src/CryptoLW-RK.h
    lib/CryptoLW-RK/src/CryptoLW.h
    lib/CryptoLW-RK/src/Speck.h
    lib/CryptoLW-RK/src/SpeckSmall.h
    lib/CryptoLW-RK/src/SpeckTiny.h
    lib/CryptoLW-RK/src/utility/EndianUtil.h
    lib/CryptoLW-RK/src/utility/LimbUtil.h
    lib/CryptoLW-RK/src/utility/ProgMemUtil.h
    lib/CryptoLW-RK/src/utility/RotateUtil.h
    lib/MB85RC256V-FRAM-RK/src/MB85RC256V-FRAM-RK.h
    lib/RF9X-RK/src/RadioHead.h
    lib/RF9X-RK/src/RF9X-RK.h
    lib/RF9X-RK/src/RH_RF95.h
    lib/RF9X-RK/src/RHDatagram.h
    lib/RF9X-RK/src/RHEncryptedDriver.h
    lib/RF9X-RK/src/RHGenericDriver.h
    lib/RF9X-RK/src/RHGenericSPI.h
    lib/RF9X-RK/src/RHHardwareSPI.h
    lib/RF9X-RK/src/RHMesh.h
    lib/RF9X-RK/src/RHReliableDatagram.h
    lib/RF9X-RK/src/RHRouter.h
    lib/RF9X-RK/src/RHSPIDriver.h
    lib/RF9X-RK/src/RX9X-RK.h
    lib/StorageHelperRK/src/StorageHelperRK.h
    src/device_pinout.h
    src/LoRA_Functions.h
    src/MyPersistentData.h
    src/take_measurements.h
    lib/CryptoLW-RK/examples/1-TestAcorn/TestAcorn.ino
    lib/CryptoLW-RK/examples/2-TestAscon/TestAscon.ino
    lib/CryptoLW-RK/examples/3-TestSpeck/TestSpeck.ino
    lib/RF9X-RK/examples/5-mesh-client/rf95_mesh_client.ino
    lib/AB1805_RK/examples/01-minimal/01-minimal.cpp
    lib/AB1805_RK/examples/02-typical/02-typical.cpp
    lib/AB1805_RK/examples/03-periodic-wake/03-periodic-wake.cpp
    lib/AB1805_RK/examples/04-selftest/04-selftest.cpp
    lib/AB1805_RK/examples/05-hwtest/05-hwtest.cpp
    lib/AB1805_RK/examples/06-supercap/06-supercap.cpp
    lib/AB1805_RK/examples/07-deep-power/07-deep-power.cpp
    lib/AB1805_RK/src/AB1805_RK.cpp
    lib/CryptoLW-RK/src/Acorn128.cpp
    lib/CryptoLW-RK/src/Ascon128.cpp
    lib/CryptoLW-RK/src/AuthenticatedCipher.cpp
    lib/CryptoLW-RK/src/BlockCipher.cpp
    lib/CryptoLW-RK/src/Cipher.cpp
    lib/CryptoLW-RK/src/Crypto.cpp
    lib/CryptoLW-RK/src/CryptoLW-RK.cpp
    lib/CryptoLW-RK/src/Speck.cpp
    lib/CryptoLW-RK/src/SpeckSmall.cpp
    lib/CryptoLW-RK/src/SpeckTiny.cpp
    lib/MB85RC256V-FRAM-RK/examples/simple/fram-simple.cpp
    lib/MB85RC256V-FRAM-RK/examples/test1m/test1m.cpp
    lib/MB85RC256V-FRAM-RK/src/MB85RC256V-FRAM-RK.cpp
    lib/RF9X-RK/examples/1-encrypted-server/rf95_encrypted_server.cpp
    lib/RF9X-RK/examples/2-encrypted-client/rf95_encrypted_client.cpp
    lib/RF9X-RK/examples/3-reliable-datagram-server/rf95_reliable_datagram_server.cpp
    lib/RF9X-RK/examples/4-reliable-datagram-client/rf95_reliable_datagram_client.cpp
    lib/RF9X-RK/examples/6-mesh-server1/rf95_mesh_server1.cpp
    lib/RF9X-RK/examples/7-mesh-server2/rf95_mesh_server2.cpp
    lib/RF9X-RK/examples/8-mesh-server3/rf95_mesh_server3.cpp
    lib/RF9X-RK/more-examples/10-reliable-datagram-client-display/src/10-reliable-datagram-client-display.cpp
    lib/RF9X-RK/src/RF9X-RK.cpp
    lib/RF9X-RK/src/RH_RF95.cpp
    lib/RF9X-RK/src/RHDatagram.cpp
    lib/RF9X-RK/src/RHEncryptedDriver.cpp
    lib/RF9X-RK/src/RHGenericDriver.cpp
    lib/RF9X-RK/src/RHGenericSPI.cpp
    lib/RF9X-RK/src/RHHardwareSPI.cpp
    lib/RF9X-RK/src/RHMesh.cpp
    lib/RF9X-RK/src/RHReliableDatagram.cpp
    lib/RF9X-RK/src/RHRouter.cpp
    lib/RF9X-RK/src/RHSPIDriver.cpp
    lib/StorageHelperRK/examples/04-persistent/04-persistent.cpp
    lib/StorageHelperRK/examples/05-eeprom/05-eeprom.cpp
    lib/StorageHelperRK/examples/06-retained/06-retained.cpp
    lib/StorageHelperRK/examples/07-validate/07-validate.cpp
    lib/StorageHelperRK/src/StorageHelperRK.cpp
    src/device_pinout.cpp
    src/LoRA_Functions.cpp
    src/LoRA-Particle-Node.cpp
    src/MyPersistentData.cpp
    src/take_measurements.cpp
    project.properties
attempting to flash firmware to your device NCParks192-SRA-JORD-Ebenezer-Relay
Processing  lib/CryptoLW-RK/examples/1-TestAcorn/TestAcorn.ino
Processing  lib/CryptoLW-RK/examples/2-TestAscon/TestAscon.ino
Processing  lib/CryptoLW-RK/examples/3-TestSpeck/TestSpeck.ino
Processing  lib/RF9X-RK/examples/5-mesh-client/rf95_mesh_client.ino
Checking library AB1805_RK...
Checking library MB85RC256V-FRAM-RK...
Checking library RF9X-RK...
Checking library CryptoLW-RK...
Checking library StorageHelperRK...
Installing library CryptoLW-RK 0.2.0 to lib/CryptoLW-RK ...
Installing library StorageHelperRK 0.0.3 to lib/StorageHelperRK ...
Installing library RF9X-RK 0.0.5 to lib/RF9X-RK ...
Installing library MB85RC256V-FRAM-RK 0.0.5 to lib/MB85RC256V-FRAM-RK ...
Installing library AB1805_RK 0.0.1 to lib/AB1805_RK ...
Library MB85RC256V-FRAM-RK 0.0.5 installed.
Library RF9X-RK 0.0.5 installed.
Library StorageHelperRK 0.0.3 installed.
Library CryptoLW-RK 0.2.0 installed.
Library AB1805_RK 0.0.1 installed.
make -C ../modules/boron/user-part all
make[1]: Entering directory `/firmware/modules/boron/user-part'
mkdir -p target/
make -f ../../../modules/shared/nRF52840/build_linker_script.mk PREBUILD=1
make[2]: Entering directory `/firmware/modules/boron/user-part'
Creating target/platform_user_ram.ld ...
make[2]: Leaving directory `/firmware/modules/boron/user-part'
make -C ../../../user
make[2]: Entering directory `/firmware/user'
Building cpp file: src/MyPersistentData.cpp
Invoking: ARM GCC CPP Compiler
mkdir -p ../build/target/user/platform-13-msrc/
arm-none-eabi-gcc -DMCU_DEVICE -DnRF52840 -DNRF52840_XXAA -DPLATFORM_THREADING=1 -DPLATFORM_ID=13 -DPLATFORM_NAME=boron -DPLATFORM_GEN=3 -DUSBD_VID_PARTICLE=0x2B04 -DUSBD_PID_DFU=0xD00D -DUSBD_PID_CDC=0xC00D -DSPARK_PLATFORM -g3 -gdwarf-2 -Os -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfloat-abi=hard -mfpu=fpv4-sp-d16 --specs=nano.specs -DINCLUDE_PLATFORM=1 -DSOFTDEVICE_PRESENT=1 -DS140 -DPRODUCT_ID=13 -DPRODUCT_FIRMWARE_VERSION=65535 -D_WIZCHIP_=W5500 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DLFS_CONFIG=lfs_config.h -DSYSTEM_VERSION_STRING=4.0.2 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../services/inc -I../third_party/nanopb/nanopb -I../communication/inc -I../hal/inc -I../hal/shared -I../hal/src/boron -I../hal/network/lwip/cellular -I../hal/src/nRF52840 -I../hal/src/armv7 -I../hal/src/nRF52840 -I../hal/src/nRF52840/lwip -I../hal/src/nRF52840/freertos -I../hal/src/nRF52840/mbedtls -I../hal/src/nRF52840/littlefs -I../hal -I../hal/src/nRF52840/posix -I../hal/network -I../hal/network/api -I../hal/network/lwip -I../hal/network/lwip/posix -I../hal/network/lwip/wiznet -I../hal/network/ncp -I../hal/network/ncp/at_parser -I../hal/network/util -I../third_party/lwip/lwip/src/include -I../third_party/freertos/freertos/FreeRTOS/Source/include -I../third_party/nrf5_sdk/nrf5_sdk/external/freertos/portable/GCC/nrf52 -I../third_party/nrf5_sdk/nrf5_sdk/external/freertos/portable/CMSIS/nrf52 -I../third_party/wiznet_driver/wiznet_driver/Ethernet -I../gsm0710muxer/gsm0710muxer/include -I../platform/shared/inc -I../third_party/nrf5_sdk -I../third_party/nrf5_sdk/nrf5_sdk/components/toolchain/cmsis/include -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx/drivers -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx/drivers/include -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx/hal -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx/mdk -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx/hal -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx/drivers/src/prs -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/util -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/s140/headers -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/s140/headers/nrf52 -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/common -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/mbr/nrf52840/headers -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/fstorage -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/experimental_section_vars -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/atomic -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/crc32 -I../third_party/nrf5_sdk/nrf5_sdk/integration/nrfx/legacy -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/delay -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/log -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/log -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/log/src -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/experimental_section_vars -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/atomic -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/delay -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/queue -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/common -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/s140 -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/s140/headers -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/s140/headers/nrf52 -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/fifo -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/atomic_fifo -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/strerror -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/fstorage -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/atomic_flags -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/usbd -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/usbd/class/cdc -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/usbd/class/cdc/acm -I../third_party/nrf5_sdk/nrf5_sdk/components/ble/common -I../third_party/nrf5_sdk/nrf5_sdk/components/ble/nrf_ble_gatt -I../third_party/nrf5_sdk/nrf5_sdk/components/ble/ble_advertising -I../third_party/nrf5_sdk/nrf5_sdk/components/nfc/t2t_lib -I../third_party/nrf5_sdk/nrf5_sdk/components/nfc/platform -I../third_party/nrf5_sdk/nrf5_sdk/components/nfc/ndef/generic/message -I../third_party/nrf5_sdk/nrf5_sdk/components/nfc/ndef/generic/record -I../third_party/nrf5_sdk/nrf5_sdk/components/nfc/ndef/lauchapp -I../third_party/nrf5_sdk/nrf5_sdk/components/nfc/ndef/text -I../third_party/nrf5_sdk/nrf5_sdk/components/nfc/ndef/uri -I../third_party/nrf5_sdk/nrf5_sdk/external/nrf_cc310/include -I../third_party/nrf5_sdk/nrf5_sdk/external/utf_converter -I../third_party/littlefs/littlefs -I../third_party/miniz/miniz -I../platform/MCU/nRF52840/inc -I../dynalib/inc -Isrc -I./libraries -Ilib/RF9X-RK/src -Ilib/StorageHelperRK/src -Ilib/MB85RC256V-FRAM-RK/src -Ilib/AB1805_RK/src -Ilib/CryptoLW-RK/src -I. -MD -MP -MF ../build/target/user/platform-13-msrc/MyPersistentData.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -fmessage-length=0 -Wno-error=deprecated-declarations -Wno-error=unused-parameter -Wimplicit-fallthrough=2 -Wno-expansion-to-defined -Wno-cast-function-type -Wno-unused-parameter -Wno-error=type-limits -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Werror=return-type -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DSPARK_PLATFORM_NET=UBLOXSARA -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc  -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DUSER_FIRMWARE_IMAGE_SIZE=0x40000 -DUSER_FIRMWARE_IMAGE_LOCATION=0xB4000 -DMODULAR_FIRMWARE=1 -DMODULE_VERSION=6 -DMODULE_FUNCTION=5 -DMODULE_INDEX=2 -DMODULE_DEPENDENCY=4,1,4006 -DMODULE_DEPENDENCY2=0,0,0 -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\""  -fno-exceptions -fno-rtti -fcheck-new -flto -ffat-lto-objects -DPARTICLE_COMPILE_LTO_FAT -fno-use-cxa-atexit -std=gnu++17 -c -o ../build/target/user/platform-13-msrc/MyPersistentData.o src/MyPersistentData.cpp
Building cpp file: src/LoRA-Particle-Node.cpp
Error: Command failed with exit code 1: /Users/chipmc/.vscode/extensions/particle.particle-vscode-core-1.15.10/src/cli/bin/darwin/amd64/particle cloud flash NCParks192-SRA-JORD-Ebenezer-Relay --target 4.0.2 --no-update-check
Including:
    src/device_pinout.h
    project.properties
mkdir -p target/
	at makeError (/Users/chipmc/.vscode/extensions/particle.particle-vscode-core-1.15.10/node_modules/execa/lib/error.js:59:11)
	at handlePromise (/Users/chipmc/.vscode/extensions/particle.particle-vscode-core-1.15.10/node_modules/execa/index.js:114:26)
	at process.processTicksAndRejections (node:internal/process/task_queues:96:5)
Any help appreciated.
Chip
