just received a pre 0.5.0 electron and flashed it in DFU-state using particle update to 0.5.3. The retained-bug wasn’t fixed(!).
As I use 0.6.0-pre2 on all other units, I uploaded the 3 system-parts using particle flash --serial system-part[1-3]-electron...bin, wich resolved that issue.
I’m quite sure that the bug is not in the 0.5.3 but in the update procedure - can anyone confirm this?
