How to remove a library after GIT repository has been deleted
Hi
it is about library conrad_rsl_switch.
I have removed the related repository from GITHUB.
But it is still listed in the published libraries of Particle Build.
By accident my Particle Build was using a different account during creation of the library. Hence, it is not listed as “my library” any more.
Who can do the job to remove the library ?
Regards
Carsten
Ping @Dave (which happened with this post already :wink: )
Hey All,
Thanks for the ping, I’ll forward this to the relevant authorities :slight_smile:
David
Hi @carsten you should log in to Build as the user which was used when importing library. The repo doesn’t need to exist for library to be unpublished.
Hi @Dave, I have a private library I would like deleted. How can this be done?
Hi @dancingpearl,
I will ask! :slight_smile:
David
Deleting libraries is not available yet. Can you please send the name of your library through https://support.particle.io and we’ll delete it for you.
Great. Thank you!
