How many wifi credentials can be loaded into the Spark Core?
My core moves with me to several wifi sites. I have had issues with Wifi not working, but my core is now fine. Any idea how many wifi sites I can load before things messup. I have 4 wifi credentials presently breathing cyan, not yet sure if the core works fine using all 4 areas, but at least they all connected.
If I’m not mistaken, the Core supports up to 7 profiles, after which the first one gets overwritten. (Could someone confirm this/add this to the docs? @kennethlimcp or @harrisonhjones perhaps?)
@Moors7, just to clarify, it is the CC3000 module which stores the wifi profiles and you are correct, it is up to 7 profiles. :smile:
