How can I fix the port problem from the device manager
I could not able to connet my particle with my computer. When I went to the device manager, I saw the driver error. I installed the driver so many time, but still, it is not working.
I got this error message, how can I solve it?
This device cannot start. (Code 10)
The specified request is not a valid operation for the target device.
Hi @ruman
Did you install Particle CLI? If not, I suggest installing this.
https://docs.particle.io/tutorials/developer-tools/cli/
Also, you can read about Particle CLI and some drivers problem in the next link
https://support.particle.io/hc/en-us/articles/1260801311330-Troubleshooting-the-Particle-CLI
yah, I fixed that, but now I am facing a device not found problem at the flashing time particle electron. How can I solve this flashing problem?
