Trouble Flashing Devices
I have an older Electron and Photo that I recently pulled back out the drawer and started playing with again.
I can get them both connected to the internet. From the Build site I can select them and signal them (to make the onboard LED change colors).
However whenever I try to flash new code to them I get an unable to connect.
What other tools should I try? Looking at older posts they seem to be 1-2 years old so I wasn’t sure if they are still applicable.
The Swiss Army Knife for Partice devices is CLI
Of all the commands in there
https://docs.particle.io/reference/cli
You’ll most likely want to use these to address your issue from above
particle update
particle flash --usb tinker
particle flash --usb <yourOwnProject.bin>
But you could also try Safe Mode first when OTA flashing fails due to your own running code interfering with the update.
