Can you help me with this problem? I am a newbie.
My USB doesn’t recognize the Electron when it is connected to it. Please see the image. And, when I flash the LED program, prompted with “serial: no serial port identified.”
You need to install the drivers.
particle setup expects the system drivers to be installed already, it doesn’t install anything on your computer.
To install the drivers you should use the CLI installer
https://binaries.particle.io/cli/installer/windows/ParticleCLISetup.exe
Or you use these
https://github.com/spark/windows-device-drivers/releases/download/v6.1.0.51/particle_drivers_6.1.0.51.exe
As documented here (found via doc-search “Windows drivers”)
https://docs.particle.io/guide/getting-started/connect/electron/#installing-the-particle-driver
Once the drivers are installed you should see the device in DevMgr as COM port device.
