I updated the tracker firmware, but my device does not wake up with motion. I believe this might be due to the motion sensitivity configuration. However, I can't find how to adjust this setting. I also noticed this configuration setting in the console under the gateway settings. Do you know how to change it?
Go into the product that the Tracker is contained in; you'll be able to configure that as a fleet setting. Even if you have only one device in your product, you configure it there.
