Hi there,
Yesterday I’ve had some troubles with one of my Photons, It was is error mode (5x red light) after I have flashed new FW into the Photon. It was running for days before. With CLI tried to recover, but still not able to connect to the cloud. It fails at verify device ownership when using the app, and via the CLI: Claiming device 2f003700154734XXXXXXXXXX
Failed to claim device, server said: Device is not connected
? Would you like to continue with the information shown above? Yes
> Obtaining device information...
> Setting up device id 2f003700154734XXXXXXXXXXXX
> Requesting public key from the device...
> Setting the magical cloud claim code...
> Telling the Photon to apply your Wi-Fi configuration...
> The Photon will now attempt to connect to your Wi-Fi network...
! It doesn't look like your Photon has made it to the cloud yet.
Now with an other Photon, I have flash it with my program, and it turns into safe mode. I’ll post my code below, maybe I’m doing something wrong:
#include "sunset.h"
#include "TimeAlarms.h"
#include <application.h>
#define OPEN 0x00
#define CLOSE 0x01
PRODUCT_ID(5XXX);
PRODUCT_VERSION(4);
unsigned long currentTime;
unsigned long lastTime = 0UL;
uint8_t DirPin = 1;
uint8_t StepPin = 2;
uint8_t SleepPin = 3;
uint16_t Steps = 50000;
uint8_t StepperDelay = 2;
uint8_t flag_request;
uint8_t flag_status;
bool CalcFlag;
pinMode(DirPin, OUTPUT);
pinMode(StepPin, OUTPUT);
pinMode(SleepPin, OUTPUT);
Time.zone(1);
//Particle.syncTime();
currentTime = now();
CalcFlag = TRUE;
flag_status = EEPROM.read(0);
RGB.control(true);
if (EEPROM.read(0) == 0x01){
RGB.color(255,0,0);
else{
RGB.color(0,255,0);
// create the alarms
Alarm.alarmRepeat(7,30,0, OpenAlarm); // 8:30am, alarm is in UTC
Alarm.alarmRepeat(4,0,0, SyncTime); // 8:30am, alarm is in UTC
//Function to run from the cloud
Particle.function("DoorControl", DoorControl);
void loop(){
CalcSunsetTime();
CheckFlagStatus();
SetColor();
//Delay of 1 second
Alarm.delay(1000);
void CheckFlagStatus(){
volatile uint8_t local_flag = flag_request;
if (flag_status /= local_flag){
//Store the open/close flag in EEPROM
EEPROM.write(0, local_flag);
StepperMotor(local_flag, 300);
void SetColor(){
if (flag_status == OPEN){
RGB.color(0,255,0);
else if (flag_status == CLOSE){
RGB.color(255,0,0);
// functions to be called when an alarm triggers:
void OpenAlarm(){
DoorControl("Open");
void CloseAlarm(){
DoorControl("Close");
void SyncTime(){
CalcFlag = TRUE;
// Calculate the sunset time for my location
void CalcSunsetTime(){
if (CalcFlag == TRUE) {
unsigned int SunSetHours;
unsigned int SunSetMinutes;
/*GPS Location @home, LAT/LON*/
double latitude = 51.77;
double longitude = -5.82;
float JD;
int SunSet;
//Since time is running in GMT, only add 1 extra hour when DST is on.
JD = calcJD(Time.year(),Time.month(),Time.day());
SunSet = calcSunsetUTC( JD, latitude, longitude) + 60;
SunSetHours = SunSet/60;
SunSetMinutes = SunSet%60;
Alarm.alarmRepeat(SunSetHours,SunSetMinutes,0, CloseAlarm);
Particle.publish("Sunset calculation done!");
CalcFlag = FALSE;
//Particle funtion to open or close the door.
int DoorControl(String Command){
if (Command == "Open"){
flag_request = OPEN;
return 1;
else if (Command == "Close"){
flag_request = CLOSE;
return 1;
else return -1;
//Funtion to control the steppermotor
void StepperMotor(int Direction, int Steps){
int i;
//Wake up motor controller
digitalWrite(SleepPin, HIGH);
if (Direction == 1){
digitalWrite(DirPin, LOW);
else{
digitalWrite(DirPin, HIGH);
for (i=0; i < Steps; i++){
digitalWrite(StepPin, HIGH);
delay(StepperDelay);
digitalWrite(StepPin, LOW);
//Put motorcontroller back in sleep
digitalWrite(SleepPin, LOW);
//This function checks the Daylight Saving Time
bool isDST()
{ // Central European Summer Timer calculation
int dayOfMonth = Time.day();
int month = Time.month();
int dayOfWeek = Time.weekday() - 1; // make Sunday 0 .. Saturday 6
if (4 <= month && month <= 9)
{ // month between April and September definetly DST
return true;
else if (month < 3 || 10 < month)
{ // before March or after October is definetly normal time
return false;
// March and October need deeper examination
boolean lastSundayOrAfter = (dayOfMonth - dayOfWeek > 24);
if (!lastSundayOrAfter)
{ // before switching Sunday
return (month == 10); // October DST will be true, March not
if (dayOfWeek)
{ // AFTER the switching Sunday
return (month == 3); // for March DST is true, for October not
int secSinceMidnightUTC = now() % 86400;
boolean dayStartedAs = (month == 10); // DST in October, in March not
// on switching Sunday we need to consider the time
if (secSinceMidnightUTC >= 1 * 3600)
{ // 1:00 UTC (=2:00 CET/3:00 CEST)
return !dayStartedAs;
return dayStartedAs;
