Having trouble Build.Particle.io claiming device on Redbear
I need help. I have breath cyan on Redbear duo and unable to accept device id on build.particle.io.
My device number is: 1c0052000xxxxxxxxxx63332
Mac Terminal.
$ screen /dev/tty.usbmodemXXXXX
I did “v”. “i”, and" w"
system firmware version: 0.2.4
Your device id is 1c0052000xxxxxxxxxx63332
SSID: Failureisnotoption
Security 0=unsecured, 1=WEP, 2=WPA, 3=WPA2: 2
Password: *******
Thanks! Wait while I save those credentials...
Awesome. Now we'll connect!
If you see a pulsing cyan light, your device
has connected to the Cloud and is ready to go!
If your LED flashes red or you encounter any other problems,
visit https://www.particle.io/support to debug.
    Particle <3 you!
I copied and paste 1c0052000xxxxxxxxxx63332 on Build.Particle.io
unable to claim device. Any ideas?
Can you try CLI
particle device add <yourDeviceID>
this might give you some extra info on the reason why the claim fails.
If that still doesn’t work, you might need to get the device re-provisioned by RedBear.
Or any of these threads might bare some hints
http://discuss.redbear.cc/search?q=claim
