Hard Fault blinking red sos, can't get into safe mode
Hey everyone,
I am trying use ParticleDev. When I try to flash and it says “Flashing via the cloud…”, it comes back with an “undefined…”
The device looks to be blinking 1 time after the SOS. I can get into DFU mode (blinking yellow), I see it blink magenta but when I release RESET it goes directly to the red hard fault.
What should I do with this blinking red hard fault?
Thanks.
–dave
Try DFU Mode with
npm update -g particle-cli
particle update
particle flash --usb tinker
particle update
Error loading command C:\Users\AppData\Roaming\npm\node_modules\particle-cli\commands\SerialCommand.js Error: Cannot find module 'node
-pre-gyp'
!!! There was an error trying execute DFU utilities.
!!! For help with installing DFU Utilities, please see:
https://docs.particle.io/guide/tools-and-features/cli/#advanced-install
!!! You may also find our community forums helpful:
https://community.particle.io/
Error code: 1
npm -g install node-pre-gyp
C:\Users\AppData\Roaming\npm\node-pre-gyp -> C:\Users\AppData\Roaming\npm\node_modules\node-pre-gyp\bin\node-pre-gyp
└── node-pre-gyp@0.6.24
c:\working>particle update
Error code: 1
Error code: 1
running dfu-util -l
Error writing firmware...dfu-util is not installed
I'm following Tutorial: Installing DFU-Driver on Windows [24 Feb 2015]
I have Zadig and installed the libusbK driver on Photon DFU Mode. I could not find CORE DFU.
I still need the dfu-utils, which I would expect to be in the installation...why do they need to be distributed separately in this strange .xz which I am unsure how to install/uncompress, which the tutorial link doesn't detail installation instruction.
https://s3.amazonaws.com/spark-assets/dfu-util-0.8-binaries.tar.xz....
7zip was able to open the archive, i copied to a path and added that path to env path.
particle update now succeeds and particle flash --usb tinker also work.
So my bad code actually requires me to flash a new firmware...lol.
Thanks for the help,
--dave
http://dave.thehorners.com/tech-talk/random-tech/545-particle-photon-sparkcore
