Particle Cannot get out of Hard Fault [RESOLVED]
My particle electron is in the SOS Hard Fault state, while updating the firmware yesterday, the system began this blinking. I cannot get into Safe mode like others.
Unfortunately I also cannot use particle update... I get the following error when in DFU mode
!!! I was unable to detect any devices in DFU mode...
Your device will blink yellow when in DFU mode.
If your device is not blinking yellow, please:
  1. Press and hold both the RESET/RST and MODE/SETUP buttons simultaneously.
  2. Release only the RESET/RST button while continuing to hold the MODE/SETUP button.
  3. Release the MODE/SETUP button once the device begins to blink yellow.
I just downloaded the dfu-util
When I run particle flash --usb tinker, it downloads but goes back to the Hard Fault state. Need help!
Thank you!
What OS are you running?
macOS
Got it working. Thanks
Twhat did you do to resolve this? No matter what I do, can’t get one of mine out of hard fault.
I’ve tried tinker, upgrade, even tried the doctor.
I can get it to DFU mode, but safe mode, wifi reset, and normal boot always go to hard fault.
