Hi
I have a local HTTPS API end point that can provide the status of my lights, room temperature etc. in my house
I want to use my Argon to facilitate GET requests from this API end point (and then publish to web via a Webhook) and trigger other actions locally on my Particle mesh network
I found the HTTPS client library - but its sending my Argon into SOS (similar to others - see here for example, HTTPS example error)
Any other tips for how I might do this? Or should I give up on using Particle/Argon to do what I wanted (maybe just a use case it isn’t suited for)
Thanks for any guidance
