Folders for Build Apps
Is there a folder system for the app build page? I’m starting to get a lot of particle apps. It’d be great to be able to put them in folders for sorting. Am I just not seeing how?
If not, any chance of adding that?
There currently isn’t a way to do that :frowning: I do believe they’re planning on working on the IDE some time in the (hopefully not-too-distant) future, during which this might be added.
If you want better file management, consider using Particle Dev, since you’re then in control :slight_smile:
