Kind of a trivial problem, in a way, but a little unnerving.
If I flash one of my Photons* it “times out” but then goes on to work just fine.
Any ideas?!
- This Photon is running an MQTT client - not sure how relevant if at all that is.
Any ideas?!
@rickkas7, @ParticleD, or @mstanley are you able to assist?
If you put the Photon into Safe mode and then flash it, does it do the same thing?
I have seen that behavior a couple times, but I don’t remember what devices it happened on.
