Fast Cyan red/orange burst
Hello, I have looked at others having this issue, but have still been unable to resolve.
History
I have a photon running off of a battery and wanted to help extend the battery life in anyway possible. One of the bright ideas I had was to put in a static IP address. After attempting to do this, I got the fast cyan with the burst ever so often.
The flash was done over the particle.io interface. I did notice I put in the wrong IP for my dns setting, so I updated and tried to push it over to the photon using the particle-cli, same fast flash.
I am on firmware 0.6.1, my id is 350047000347333439313830
I am on Win10
I have the photon plugged into a sparkfun weather station, and I have left it in there, very tight fit, hard to get out would that cause an issue with trying to fix? I do not know
I have tried all kinds of things
I have since unclaimed my device too, as I said I was grasping at straws here…
I am able to flash tinker, I can update the wifi settings, but I keep getting a fast cyan.
I even tried putting 0.6.0, and then did the particle update, same thing
Weird thing is that I keep getting the static IP showing up on my router, and it says that it is a static IP address, even after flashing and resetting the wifi settings on the photon.
The only thing I did not do was flashing a file for the radio cc3000, only because I do not have it and I have been unable to locate it.
I tried doing the same things and trying to connect to my verizon tablet, same fast flash
Hopefully this is something simple and overlooked.
HELP!
Lets start from the beginning
anyone!
right now I have the flashing yellow with a flashing blue d7 led
Here is one of latest things I tried
"D:\Particle\WeatherStationWorking\src>particle flash --usb WeatherStationWorking.ino
Found DFU device 2b04:d006
Error writing firmware...CRC is invalid, use --force to override
D:\Particle\WeatherStationWorking\src>particle flash --usb WeatherStationWorking.ino --force
spawning dfu-util -d 2b04:d006 -a 0 -i 0 -s 0x080A0000:leave -D WeatherStationWorking.ino
dfu-util 0.8
ID 2b04:d006
Claiming USB DFU Interface...
dfuIDLE, continuing
Downloading to address = 0x080a0000, size = 18181
Download        [=========================] 100%        18181 bytes
Download done.
File downloaded successfully
Invalid DFU suffix signature
Flash success!
D:\Particle\WeatherStationWorking\src>particle keys doctor 350047000347333439313830
New Key Created!
This file already exists, please specify a different file, or use the --force flag.
Continuing...
spawning dfu-util -d 2b04:d006 -a 1 -i 0 -s 34:leave -D 350047000347333439313830_rsa_new.der
dfu-util 0.8
ID 2b04:d006
Setting Alternate Setting #1 ...
dfuIDLE, continuing
DfuSe interface name: "DCT Flash   "
Downloading to address = 0x00000022, size = 608
Download        [=========================] 100%          608 bytes
Download done.
Saved!
attempting to add a new public key for device 350047000347333439313830
submitting public key succeeded!
Okay!  New keys in place, your device should restart.
Unclaiming never solves such issues.
The Photon also has no CC3000 module :wink:
Once you had flashed a application that used WiFi.staticIP() you need to flash another application that explicitly executes WiFi.dynamicIP() WiFi.useDynamicIP() to go back to DHCP IP request.
Tinker alone won’t revert back to dynamic IP
If your CRC does not fit, I’d rather not use --force but double or tripple check if the binary is actually compatible and probably rebuild the binary.
Thanks ScruffR,
I added WiFi.useDynamicIP(); to void setup() to my ino file.
I tried using the WiFi.dynamicIP() but it would not verify
Then I did this ( am I doing this right?)
D:\Particle\WeatherStationWorking\src>particle flash --usb WeatherStationWorking.ino sparkfun_photon_weather_shield_library.cpp sparkfun_photon_weather_shield_library.h
D:\Particle\WeatherStationWorking\src>particle flash --usb WeatherStationWorking.ino sparkfun_photon_weather_shield_library.cpp sparkfun_photon_weather_shield_library.h --force
dfu-util 0.8
ID 2b04:d006
dfuIDLE, continuing
Downloading to address = 0x080a0000, size = 18183
Download        [=========================] 100%        18183 bytes
Download done.
Flash success!
Same fast cyan
I am doing something wrong here…
Thank you for helping
Perhaps you can provide me with a file (with all the right stuff in it) to flash to the photon that will magically solve this issue?
Just copy this into a file dynamicIP.cpp
#include <Particle.h>
SYSTEM_MODE(MANUAL)
  WiFi.on();
  WiFi.clearCredentials();
  pinMode(D7, OUTPUT);
  digitalWrite(D7, !digitalRead(D7));
  delay(250);
then execute this in the same directory where you created that file
particle compile photon dynamicIP.cpp --target 0.6.0 --saveTo firmware.bin
then put your device into DFU Mode
particle update
particle flash --usb firmware.bin
After that you will have to reenter the WiFi credentials in Listening Mode via
particle serial wifi
If you then have the red bursts again retry
particle keys server
(assuming 350047000347333439313830 is your device ID)
Ok now I have a breathing blue light and a flashing d7
If I hit reset it goes white real quick and then back to breathing blue light and a flashing d7
D:\Particle\scruff>particle compile photon dynamicIP.cpp --target 0.6.0 --saveTo firmware.bin
Compiling code for photon
Targeting version: 0.6.0
Including:
    dynamicIP.cpp
downloading binary from: /v1/binaries/58dab12b27539b01aa04b7a7
saving to: firmware.bin
Memory use:
   text    data     bss     dec     hex filename
   5612       8    1484    7104    1bc0
Compile succeeded.
Saved firmware to: D:\Particle\scruff\firmware.bin
D:\Particle\scruff>particle update
> Your device is ready for a system update.
> This process should take about 30 seconds. Here goes!
! System firmware update successfully completed!
> Your device should now restart automatically.
> You may need to re-flash your application to the device.
D:\Particle\scruff>particle flash --usb firmware.bin
spawning dfu-util -d 2b04:d006 -a 0 -i 0 -s 0x080A0000:leave -D firmware.bin
dfu-util 0.8
ID 2b04:d006
dfuIDLE, continuing
Downloading to address = 0x080a0000, size = 5620
Download        [=========================] 100%         5620 bytes
Download done.
Flash success!
setup the wfi
success
D:\Particle\scruff>particle keys server
spawning dfu-util -d 2b04:d006 -a 1 -i 0 -s 2082 -D C:\Users\cjslk\AppData\Local\particle\node_modules\particle-cli\keys\rsa.pub.der
dfu-util 0.8
ID 2b04:d006
dfuIDLE, continuing
Downloading to address = 0x00000822, size = 512
Download        [=========================] 100%          512 bytes
Download done.
Okay!  New keys in place, your device will not restart.
D:\Particle\scruff>particle keys doctor 350047000347333439313830
New Key Created!
Saved!
dfu-util 0.8
ID 2b04:d006
dfuIDLE, continuing
Downloading to address = 0x00000022, size = 607
Download        [=========================] 100%          607 bytes
Download done.
Saved!
I cleared the wifi again, set it back up
then I got breathing green and a flashing d7
I hit reset it goes back to breathing blue flashing d7
That is normal due to SYSTEM_MODE(MANUAL).
This was only a sketch to reset the to dynamic IP - after that you can flash your own code or Tinker
particle flash --usb tinker
Or you can try Safe Mode to see if the device can enter breathing magenta.
Holy moly! Yaaaaay, it is working now. Thaaaaaaaaaaaaank Yooooooooooouuuu
Had to run through all the steps again, but it worked, maybe I am insane
1 more question, about the rgb led
I have it set to deep sleep wake up and post the weather. When it wakes up it flashes, posts the data, then goes back to sleep.
Can I turn off the led entirely. I don’t know how much energy this would save anyway. My only other option is a bigger battery I guess for my energy problem. I have a solor panel, but it does not want to keep up, one of my other issues
I currently have
#define RBG_NOTIFICATIONS_OFF
#include <rgb-controls.h>  //led control
and
RGB.control(true);
    delay(1000);
    RGB.brightness(0);
but this just seems to control the led if it was left on
anyways, thank you again.
-Chris
I have some other questions about my weatherstation setup, but I will start a new thread for that stuff.
No need for that extra include and I’d do it this way
void ledOff() {
  RGB.control(true);
  RGB.color(0,0,0);
  RGB.brightness(0);
#if defined(RBG_NOTIFICATIONS_OFF)
STARTUP(ledOff();)
#endif
// here follows the rest of your code
But power saving will be marginal.
I’d rather check whether all sensors will be depowered while sleeping.
How do you turn off the sensors, I though deep sleep would do that?
I would like the rain sensor to stay on I guess, if it would be by itself.
Here is my cobbled together code from here and there. There is probably alot of cleaning that can be done, but at least it works for the most part. The only thing is I have not been able to get the wind gust stuff working right.
  SparkFun_Photon_Weather_Wunderground.ino
  SparkFun Photon Weather Shield basic example
  Joel Bartlett @ SparkFun Electronics
  Original Creation Date: May 18, 2015
  Updated August 21, 2015
  This sketch prints the temperature, humidity, and barometric pressure OR
  altitude to the Serial port.
  The library used in this example can be found here:
  https://github.com/sparkfun/SparkFun_Photon_Weather_Shield_Particle_Library
  Hardware Connections:
	This sketch was written specifically for the Photon Weather Shield,
	which connects the HTU21D and MPL3115A2 to the I2C bus by default.
  If you have an HTU21D and/or an MPL3115A2 breakout,	use the following
  hardware setup:
      HTU21D ------------- Photon
      (-) ------------------- GND
      (+) ------------------- 3.3V (VCC)
       CL ------------------- D1/SCL
       DA ------------------- D0/SDA
    MPL3115A2 ------------- Photon
      GND ------------------- GND
      VCC ------------------- 3.3V (VCC)
      SCL ------------------ D1/SCL
      SDA ------------------ D0/SDA
  Development environment specifics:
  	IDE: Particle Dev
  	Hardware Platform: Particle Photon
                       Particle Core
  This code is beerware; if you see me (or any other SparkFun
  employee) at the local, and you've found our code helpful,
  please buy us a round!
  Distributed as-is; no warranty is given.
  Weather Underground Upload sections: Dan Fein @ Weather Underground
  Weather Underground Upload Protocol:
  http://wiki.wunderground.com/index.php/PWS_-_Upload_Protocol
  Sign up at http://www.wunderground.com/personal-weather-station/signup.asp
#include "SparkFun_Photon_Weather_Shield_Library.h"
#include "math.h"   //For Dew Point Calculation
int WDIR = A0;
int RAIN = D2;
int WSPEED = D3; //march2017
long lastSecond; //The millis counter to see when a second rolls by
byte seconds; //When it hits 60, increase the current minute
byte seconds_2m; //Keeps track of the "wind speed/dir avg" over last 2 minutes array of data
byte minutes; //Keeps track of where we are in various arrays of data
byte minutes_10m; //Keeps track of where we are in wind gust/dir over last 10 minutes array of data
//We need to keep track of the following variables:
//Wind speed/dir each update (no storage)
//Wind gust/dir over the day (no storage)
//Wind speed/dir, avg over 2 minutes (store 1 per second)
//Wind gust/dir over last 10 minutes (store 1 per minute)
//Rain over the past hour (store 1 per minute)
//Total rain over date (store one per day)
byte windspdavg[120]; //120 bytes to keep track of 2 minute average
int winddiravg[120]; //120 ints to keep track of 2 minute average
float windgust_10m[10]; //10 floats to keep track of 10 minute max
int windgustdirection_10m[10]; //10 ints to keep track of 10 minute max
volatile float rainHour[60]; //60 floating numbers to keep track of 60 minutes of rain
//These are all the weather values that wunderground expects:
int winddir = 0; // [0-360 instantaneous wind direction]
float windspeedmph = 0; // [mph instantaneous wind speed]
float windgustmph = 0; // [mph current wind gust, using software specific time period]
int windgustdir = 0; // [0-360 using software specific time period]
float windspdmph_avg2m = 0; // [mph 2 minute average wind speed mph]
int winddir_avg2m = 0; // [0-360 2 minute average wind direction]
float windgustmph_10m = 0; // [mph past 10 minutes wind gust mph ]
int windgustdir_10m = 0; // [0-360 past 10 minutes wind gust direction]
float rainin = 0; // [rain inches over the past hour)] -- the accumulated rainfall in the past 60 min
long lastWindCheck = 0;
volatile float dailyrainin = 0; // [rain inches so far today in local time] march2017
float humidity = 0;
float humTempF = 0;  //humidity sensor temp reading, fahrenheit
float humTempC = 0;  //humidity sensor temp reading, celsius
float baroTempF = 0; //barometer sensor temp reading, fahrenheit
float baroTempC = 0; //barometer sensor temp reading, celsius
float tempF = 0;     //Average of the sensors temperature readings, fahrenheit
float tempC = 0;     //Average of the sensors temperature readings, celsius
float dewptF = 0;
float dewptC = 0;
float pascals = 0;
float inches = 0;
//Wunderground Vars
char SERVER[] = "rtupdate.wunderground.com";        //Rapidfire update server - for multiple sends per minute
//char SERVER [] = "/rtupdate.wunderground.com/weatherstation/updateweatherstation.php?";   //Standard server - for sends once per minute or less
char WEBPAGE [] = "GET /weatherstation/updateweatherstation.php?";
//Station Identification
char ID [] = "KTNALAMO3"; //Your station ID here
char PASSWORD [] = "#######"; //your Weather Underground password here
TCPClient client;
// volatiles are subject to modification by IRQs
volatile long lastWindIRQ = 0; //march 2017
volatile byte windClicks = 0;
volatile unsigned long raintime, rainlast, raininterval, rain; // march2017
//Create Instance of HTU21D or SI7021 temp and humidity sensor and MPL3115A2 barometric sensor
Weather sensor;
//Interrupt routines (these are called by the hardware interrupts, not by the main code)
//-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=march2017
void rainIRQ()
// Count rain gauge bucket tips as they occur
// Activated by the magnet and reed switch in the rain gauge, attached to input D2
  raintime = millis(); // grab current time
  raininterval = raintime - rainlast; // calculate interval between this and last event
    if (raininterval > 10) // ignore switch-bounce glitches less than 10mS after initial edge
    dailyrainin += 0.011; //Each dump is 0.011" of water
    rainHour[minutes] += 0.011; //Increase this minute's amount of rain
    rainlast = raintime; // set up for next event
void wspeedIRQ()
// Activated by the magnet in the anemometer (2 ticks per rotation), attached to input D3
  if (millis() - lastWindIRQ > 10) // Ignore switch-bounce glitches less than 10ms (142MPH max reading) after the reed switch closes
    lastWindIRQ = millis(); //Grab the current time
    windClicks++; //There is 1.492MPH for each click per second.
//march2017
    RGB.control(true);
    delay(1000);
    RGB.brightness(0);
    Serial.begin(9600);   // open serial over USB at 9600 baud
    //Initialize the I2C sensors and ping them
    sensor.begin();
    pinMode(WSPEED, INPUT_PULLUP); // input from wind meters windspeed sensor
    pinMode(RAIN, INPUT_PULLUP); // input from wind meters rain gauge sensor march 2017
    /*You can only receive acurate barrometric readings or acurate altitiude
    readings at a given time, not both at the same time. The following two lines
    tell the sensor what mode to use. You could easily write a function that
    takes a reading in one made and then switches to the other mode to grab that
    reading, resulting in data that contains both acurate altitude and barrometric
    readings. For this example, we will only be using the barometer mode. Be sure
    to only uncomment one line at a time. */
    sensor.setModeBarometer();//Set to Barometer Mode
    //baro.setModeAltimeter();//Set to altimeter Mode
    //These are additional MPL3115A2 functions the MUST be called for the sensor to work.
    sensor.setOversampleRate(7); // Set Oversample rate
    //Call with a rate from 0 to 7. See page 33 for table of ratios.
    //Sets the over sample rate. Datasheet calls for 128 but you can set it
    //from 1 to 128 samples. The higher the oversample rate the greater
    //the time between data samples.
    sensor.enableEventFlags(); //Necessary register calls to enble temp, baro ansd alt
    seconds = 0;
    lastSecond = millis();
    // attach external interrupt pins to IRQ functions
    attachInterrupt(RAIN, rainIRQ, FALLING);
    attachInterrupt(WSPEED, wspeedIRQ, FALLING);
    // turn on interrupts
    interrupts();
      //Get readings from all sensors
      getWeather();
      //Print to console  //console off during wireless
      //Send data to Weather Underground
      sendToWU();
delay(5000);
      //Power down between sends to save power, measured in seconds.
   System.sleep(SLEEP_MODE_DEEP,25);  //for Particle Photon
      //Spark.sleep(SLEEP_MODE_DEEP,300);   //for Spark Core
void printInfo()
//This function prints the weather data out to the default Serial Port
      Serial.print("Wind_Dir:");
      switch (winddir)
        case 0:
          Serial.print("North");
          break;
        case 45:
          Serial.print("NE");
          break;
        case 90:
          Serial.print("East");
          break;
        case 135:
          Serial.print("SE");
          break;
        case 180:
          Serial.print("South");
          break;
        case 225:
          Serial.print("SW");
          break;
        case 270:
          Serial.print("West");
          break;
        case 315:
          Serial.print("NW");
          break;
        default:
          Serial.print("No Wind");
          // if nothing else matches, do the
          // default (which is optional)
      Serial.print(" Wind_Speed:");
      Serial.print(windspeedmph, 1);
      Serial.print("mph, ");
      Serial.print("Rain:");
      Serial.print(rainin, 2);
      Serial.print("in., ");
  Serial.print("Temp:");
  Serial.print(tempF);
  Serial.print("F, ");
  Serial.print("Humidity:");
  Serial.print(humidity);
  Serial.print("%, ");
  Serial.print("Baro_Temp:");
  Serial.print(baroTempF);
  Serial.print("Humid_Temp:");
  Serial.print(humTempF);
  Serial.print("Pressure:");
  Serial.print(pascals/100);
  Serial.print("hPa, ");
  Serial.print(inches);
  Serial.println("in.Hg");
  //The MPL3115A2 outputs the pressure in Pascals. However, most weather stations
  //report pressure in hectopascals or millibars. Divide by 100 to get a reading
  //more closely resembling what online weather reports may say in hPa or mb.
  //Another common unit for pressure is Inches of Mercury (in.Hg). To convert
  //from mb to in.Hg, use the following formula. P(inHg) = 0.0295300 * P(mb)
  //More info on conversion can be found here:
  //www.srh.noaa.gov/images/epz/wxcalc/pressureConversion.pdf
  //If in altitude mode, print with these lines
  //Serial.print("Altitude:");
  //Serial.print(altf);
  //Serial.println("ft.");
//Read the wind direction sensor, return heading in degrees
int get_wind_direction()
  unsigned int adc;
  adc = analogRead(WDIR); // get the current reading from the sensor
  // The following table is ADC readings for the wind direction sensor output, sorted from low to high.
  // Each threshold is the midpoint between adjacent headings. The output is degrees for that ADC reading.
  // Note that these are not in compass degree order! See Weather Meters datasheet for more information.
  //Wind Vains may vary in the values they return. To get exact wind direction,
  //it is recomended that you AnalogRead the Wind Vain to make sure the values
  //your wind vain output fall within the values listed below.
  if(adc > 2270 && adc < 2290) return (0);//North
  if(adc > 3220 && adc < 3299) return (45);//NE
  if(adc > 3890 && adc < 3999) return (90);//East
  if(adc > 3780 && adc < 3850) return (135);//SE
  if(adc > 3570 && adc < 3650) return (180);//South
  if(adc > 2790 && adc < 2850) return (225);//SW
  if(adc > 1580 && adc < 1610) return (270);//West
  if(adc > 1930 && adc < 1950) return (315);//NW
  //return (-1); // error, disconnected?
//Returns the instataneous wind speed
float get_wind_speed()
  float deltaTime = millis() - lastWindCheck; //750ms
  deltaTime /= 1000.0; //Covert to seconds
  float windSpeed = (float)windClicks / deltaTime; //3 / 0.750s = 4
  windClicks = 0; //Reset and start watching for new wind
  lastWindCheck = millis();
  windSpeed *= 1.492; //4 * 1.492 = 5.968MPH
  /* Serial.println();
   Serial.print("Windspeed:");
   Serial.println(windSpeed);*/
  return(windSpeed);
void sendToWU()
  Serial.println("connecting...");
  if (client.connect(SERVER, 80)) {
  Serial.println("Connected");
  client.print(WEBPAGE);
  client.print("ID=");
  client.print(ID);
  client.print("&PASSWORD=");
  client.print(PASSWORD);
  client.print("&dateutc=now");      //can use 'now' instead of time if sending in real time
  client.print("&tempf=");
  client.print(tempF-4);
  client.print("&dewptf=");
  client.print(dewptF);
  client.print("&humidity=");
  client.print(humidity);
  client.print("&baromin=");
  client.print(inches);
  //client.print("&windspeedmph=");
  //client.print(windspeedmph);
  client.print("&rainin=");
  client.print(rainin);
  client.print("&winddir="); //- [0-360 instantaneous wind direction]
  client.print(winddir);
  client.print("&windspeedmph="); //- [mph instantaneous wind speed]
  client.print("&windgustmph="); //- [mph current wind gust, using software specific time period]
  client.print(windgustmph);
  client.print("&windgustdir="); //- [0-360 using software specific time period]
  client.print(windgustdir);
  client.print("&windspdmph_avg2m=");  //- [mph 2 minute average wind speed mph]
  client.print(windspdmph_avg2m);
  client.print("&winddir_avg2m="); //- [0-360 2 minute average wind direction]
  client.print(winddir_avg2m);
  client.print("&windgustmph_10m="); // - [mph past 10 minutes wind gust mph ]
  client.print(windgustmph_10m);
  client.print("&windgustdir_10m=");// - [0-360 past 10 minutes wind gust direction]
  client.print(windgustdir_10m);
  //client.print("&action=updateraw");    //Standard update rate - for sending once a minute or less
  client.print("&softwaretype=Particle-Photon&action=updateraw&realtime=1&rtfreq=30");  //Rapid Fire update rate - for sending multiple times per minute, specify frequency in seconds
  client.println(" HTTP 1.1"); // note the space before HTTP
  client.println("Host: rtupdate.wunderground.com");
  client.println("Connection: close");
  client.println();
    Serial.println("Upload complete");
  delay(5000);                         //Without the delay it goes to sleep too fast and the send is unreliable
  }else{
    Serial.println(F("Connection failed"));
  return;
void getWeather()
  // Measure Relative Humidity from the HTU21D or Si7021
  humidity = sensor.getRH();
  // Measure Temperature from the HTU21D or Si7021
  humTempC = sensor.getTemp();
  humTempF = (humTempC * 9)/5 + 32;
  // Temperature is measured every time RH is requested.
  // It is faster, therefore, to read it from previous RH
  // measurement with getTemp() instead with readTemp()
  //Measure the Barometer temperature in F from the MPL3115A2
  baroTempC = sensor.readBaroTemp();
  baroTempF = (baroTempC * 9)/5 + 32; //convert the temperature to F
  //Measure Pressure from the MPL3115A2
  pascals = sensor.readPressure();
  inches = pascals * 0.0002953; // Calc for converting Pa to inHg (Wunderground expects inHg)
  //If in altitude mode, you can get a reading in feet with this line:
  //float altf = sensor.readAltitudeFt();
  //Average the temperature reading from both sensors
  tempC=((humTempC+baroTempC)/2);
  tempF=((humTempF+baroTempF)/2);
  //Calculate Dew Point
  dewptC = dewPoint(tempC, humidity);
  dewptF = (dewptC * 9.0)/ 5.0 + 32.0;
//Calc winddir
    winddir = get_wind_direction();
    //Calc windspeed
    windspeedmph = get_wind_speed();
    //Keep track of which minute it is
  if(millis() - lastSecond >= 1000)
    lastSecond += 1000;
    //Take a speed and direction reading every second for 2 minute average
    if(++seconds_2m > 119) seconds_2m = 0;
    //Calc the wind speed and direction every second for 120 second to get 2 minute average
    float currentSpeed = get_wind_speed();
    //float currentSpeed = random(5); //For testing
    int currentDirection = get_wind_direction();
    windspdavg[seconds_2m] = (int)currentSpeed;
    winddiravg[seconds_2m] = currentDirection;
    //if(seconds_2m % 10 == 0) displayArrays(); //For testing
    //Check to see if this is a gust for the minute
    if(currentSpeed > windgust_10m[minutes_10m])
      windgust_10m[minutes_10m] = currentSpeed;
      windgustdirection_10m[minutes_10m] = currentDirection;
    //Check to see if this is a gust for the day
    if(currentSpeed > windgustmph)
      windgustmph = currentSpeed;
      windgustdir = currentDirection;
    if(++seconds > 59)
      seconds = 0;
      if(++minutes > 59) minutes = 0;
      if(++minutes_10m > 9) minutes_10m = 0;
      rainHour[minutes] = 0; //Zero out this minute's rainfall amount
      windgust_10m[minutes_10m] = 0; //Zero out this minute's gust
    //Total rainfall for the day is calculated within the interrupt
    //Calculate amount of rainfall for the last 60 minutes
    rainin = 0;
    for(int i = 0 ; i < 60 ; i++)
      rainin += rainHour[i];
// dewPoint function from NOAA
// reference (1) : http://wahiduddin.net/calc/density_algorithms.htm
// reference (2) : http://www.colorado.edu/geography/weather_station/Geog_site/about.htm
double dewPoint(double celsius, double humidity)
	// (1) Saturation Vapor Pressure = ESGG(T)
	double RATIO = 373.15 / (273.15 + celsius);
	double RHS = -7.90298 * (RATIO - 1);
	RHS += 5.02808 * log10(RATIO);
	RHS += -1.3816e-7 * (pow(10, (11.344 * (1 - 1/RATIO ))) - 1) ;
	RHS += 8.1328e-3 * (pow(10, (-3.49149 * (RATIO - 1))) - 1) ;
	RHS += log10(1013.246);
  // factor -3 is to adjust units - Vapor Pressure SVP * humidity
	double VP = pow(10, RHS - 3) * humidity;
  // (2) DEWPOINT = F(Vapor Pressure)
	double T = log(VP/0.61078);   // temp var
	return (241.88 * T) / (17.558 - T);
	// Delay for 10 sec before next reading // added by JDM
delay(5000);
First, I keep reformatting your code blocks.
Please wrap your code blocks in a set of these to make them look neat
 ```cpp
 // your code
see https://community.particle.io/t/forum-tips-and-tricks/3999
[quote="MrTAAnderson, post:11, topic:31059"]
[/quote]
That depends how they are wired.
In deep sleep 3v3 and Vin will still provide power, so all sensors directly powered that way will keep drawing current unless they have a power down feature that your code needs to trigger.
Or you control the power supply for them via another pin.
Yes, I admit it could look alot better
Here is the schematic for the sensors if you wanted to see it, I cannot change the pins since the photon plugs directly into the shield.
I do not know about any power down features, I would have to go look at the documentation on the weather shield…
-Thank You
Nice… The voltage regulator enable pin is tied high…
Not sure what you can do to shut the sensors off easily.
The Sparkfun people can probably help you if there is a possibility that I am not seeing.
