The whole thing is kinda a box in a box, the photon is in an enclosure which is then within a machine. I am looking to mount the antenna to the outside of the machine. Would I just be able to take an SMA cable, run it from the photon enclosure, and then to the exterior of the machine to then attach the end of the antenna to?
Thanks, I figured it would work out fine but I was looking for a second opinion. I also didn’t know about the difference between Reverse Polarity and Regular, thank for point that out.
