I am fairly new with the photon, and I am unaware of how much larger in radius the photon will be able to connect cleanly to the wifi with this antenna. I see 2.4 GHz, but I am unaware of what this number means in relation to the frequency of the photon, which I do not know after looking through the schematic. So an antenna with an extremely large radius to the wifi router is a must. In fact, the larger the better!
I am looking to instal this is a smaller device using the P1 board. How do I install the antenna to the P1 board?
Jeff, any antenna for 2.4GHz will work it needs a tail/wire with a uFL connector. There are many suppliers: Molex, TE connectivity, etc. The P1 has a uFL connector.
Hello! I’ve been using these on my devices for some time with great results. A lot cheaper than the Particle supplied ones. Plus Amazon Prime shipping, so way cheaper there as well.
The RF gain is typically 3.5 to 4 dB which does not sound much but is actually quite useful, I have found that setting the antenna to external and fitting one of these antennas to be a worthwhile investment to improve connectivity.
