Electron with SIM Card is no longer connecting
Recently re-activated my Electron as well as the SIM card. It activated successfully; however, after adding in my Boron device successfully, I had to run the setup on the Electron again no longer connects only blinks Fast Green. It feels like something is up with the SIM card. It was last used in 2021, and shows active in my Console.
How do I get assistance to get this resolved to bring the device online?
The best option is to use the Web device doctor to flash troubleshooting firmware to the device and get a debug log to determine what exactly is failing.
There does not appear to be a Particle account with the same email used in this forum so I could not check the SIM status.
Also, which model of Electron? Is this an Electron 2G/3G with a physical SIM card or an Electron LTE (ELC402 or ELC404)? And what country are you in? If you are in the United States or Canada, it's likely that the ELC310 (or Electron U260) will no longer be able to connect due to the 2G/3G sunset.
I didn’t realize I used my other email address when signing up. I updated my profile accordingly so they now match. Let me know if you need logs for a longer period.
0000010001 [app] INFO: Connecting to the cloud
0000010004 [system] INFO: ARM_WLAN_WD 1
10.004 AT send       4 "AT\r\n"
10.009 AT read OK    6 "\r\nOK\r\n"
[ Modem::register ] = = = = = = = = = = = = = =
10.009 AT send      10 "AT+CFUN?\r\n"
10.016 AT read  +   14 "\r\n+CFUN: 1,0\r\n"
10.017 AT read OK    6 "\r\nOK\r\n"
10.017 AT send      12 "AT+CGREG=2\r\n"
10.022 AT read OK    6 "\r\nOK\r\n"
10.022 AT send      11 "AT+CREG=2\r\n"
10.027 AT read OK    6 "\r\nOK\r\n"
10.027 AT send       8 "AT+CSQ\r\n"
10.032 AT read  +   15 "\r\n+CSQ: 99,99\r\n"
10.033 AT read OK    6 "\r\nOK\r\n"
10.033 AT send      10 "AT+CREG?\r\n"
10.039 AT read  +   14 "\r\n+CREG: 2,0\r\n"
10.040 AT read OK    6 "\r\nOK\r\n"
10.040 AT send      11 "AT+CGREG?\r\n"
10.045 AT read  +   15 "\r\n+CGREG: 2,0\r\n"
10.046 AT read OK    6 "\r\nOK\r\n"
10.046 AT send      10 "AT+URAT?\r\n"
10.052 AT read  +   14 "\r\n+URAT: 1,2\r\n"
10.053 AT read OK    6 "\r\nOK\r\n"
10.053 AT send       4 "AT\r\n"
10.056 AT read OK    6 "\r\nOK\r\n"
10.056 AT send      10 "AT+CFUN?\r\n"
10.062 AT read  +   14 "\r\n+CFUN: 1,0\r\n"
10.063 AT read OK    6 "\r\nOK\r\n"
10.063 AT send      10 "AT+COPS?\r\n"
10.068 AT read  +   12 "\r\n+COPS: 0\r\n"
10.069 AT read OK    6 "\r\nOK\r\n"
10.069 AT send       8 "AT+CSQ\r\n"
10.074 AT read  +   15 "\r\n+CSQ: 99,99\r\n"
10.075 AT read OK    6 "\r\nOK\r\n"
10.075 AT send      10 "AT+CREG?\r\n"
10.081 AT read  +   14 "\r\n+CREG: 2,0\r\n"
10.082 AT read OK    6 "\r\nOK\r\n"
10.082 AT send      11 "AT+CGREG?\r\n"
10.087 AT read  +   15 "\r\n+CGREG: 2,0\r\n"
10.088 AT read OK    6 "\r\nOK\r\n"
25.092 AT send       8 "AT+CSQ\r\n"
26.903 AT read  +   15 "\r\n+CSQ: 99,99\r\n"
26.904 AT read OK    6 "\r\nOK\r\n"
26.904 AT send      10 "AT+CREG?\r\n"
26.909 AT read  +   14 "\r\n+CREG: 2,0\r\n"
26.910 AT read OK    6 "\r\nOK\r\n"
26.910 AT send      11 "AT+CGREG?\r\n"
26.915 AT read  +   15 "\r\n+CGREG: 2,0\r\n"
26.916 AT read OK    6 "\r\nOK\r\n"
Sticky not registering CSD state for 16 s, PLMN reselection
26.927 AT send      13 "AT+COPS=0,2\r\n"
29.340 AT read ERR  34 "\r\n+CME ERROR: no network service\r\n"
41.926 AT send       8 "AT+CSQ\r\n"
43.742 AT read  +   15 "\r\n+CSQ: 99,99\r\n"
43.743 AT read OK    6 "\r\nOK\r\n"
43.743 AT send      10 "AT+CREG?\r\n"
43.748 AT read  +   14 "\r\n+CREG: 2,0\r\n"
43.749 AT read OK    6 "\r\nOK\r\n"
43.749 AT send      11 "AT+CGREG?\r\n"
43.755 AT read  +   15 "\r\n+CGREG: 2,0\r\n"
43.756 AT read OK    6 "\r\nOK\r\n"
Disregard, I have realized this is a 3G model. My apologies and appreciate the support and patience.
