I’ve had a couple of enquires about electron compatibility with my protoboards so I though i’d post the answer here.
The protoboards are electrically compatible with the electron.
The board a similar same size to the photon so if your using the included female headers the extra pins will just hang out over the end of the protoboard. If you want to solder the protoboard directly to the electron you will have to remove some pins from the electron to make it fit I’m guessing C5,C4,B5,B4.
The board was originally designed for the Core and there are a couple of labelling differences between the Core and the Photon/Electron.
A6 -> DAC
A7 -> WKP
3v3* -> VBAT
Now I’d like to post a big bunch of protoboards this week so for $3 off the five pack enter the discount code 9E3BE646 for the next ten sales or to the end of the month.
