I reflashed the f/w last night with unchanged code (see below) but told my linux box to stop polling for information every minute. I also did NOT have a serial console open. My core has been running for almost 12 hours without issue. I just opened up a serial console and will see if that lasts for over 2 hours (my previous record). If so, then I’ll re-enable my cron job and start polling for values and see how that goes.
It may be that requesting info from the core every minute increases the likelihood of a network issue. However, I thought I read somewhere that spark was pinging something every 15 seconds or so. I’ll report back with what I find. I’m hoping this is helpful.
@Dave - You mentioned “bug where the core doesn’t always reconnect on its own”. Just to be clear, once I get the blue-flash-of-death, my core never reconnects without a physical reset.
Dave O
int uptime, data;
const int LED=D7;
const int ANALOG=D1;
const unsigned long DELAY_TIME = 10000; // number of milliseconds
unsigned long delayTimer = 0;
Spark.variable("uptime", &uptime, INT);
Spark.variable("data", &data, INT);
pinMode(LED, OUTPUT);
Serial.begin(9600);
delayTimer = millis ();
void loop(void) {
if (millis () - delayTimer > DELAY_TIME) // Run this function every DELAY_TIME milliseconds
// Turn on the LED when reading temperature - should be every DELAY_TIME
digitalWrite(LED, HIGH);
delay (2000); // Tossing this in as a "reasonable" delay that a temperature reading might encounter
digitalWrite(LED, LOW);
delayTimer = millis (); // update delayTime to new value of millis ()
uptime = delayTimer / 1000; // keep track of how many *seconds* the spark has been running.
Serial.print ("uptime is ");
Serial.print (uptime);
Serial.print (" seconds, ~");
Serial.print (uptime / 60);
Serial.print (" minutes ");
data = analogRead(ANALOG);
Serial.print ("Data from ANALOG = ");
Serial.println (data);
