im struggling with dim d7 led light
any can help with a detailed step by step jtag process
( the one in faqs does not cover all config settings )
thanks
thanks
Don’t know what jtag is, but with this code snippet you can control the Photon RGB LED - I´m on the right way (I know this differs to D7)?
void setup:
RGB.control(true);
void loop:
RGB.color(255, 0 ,0);
delay(2000);
RGB.color(0, 255, 0);
delay(2000);
RGB.color(0, 0, 255);
delay(2000);
That won’t help a lot. When calling for JTAG with the dim D7 issue, the device is in a state where you need to get a bit more hard core
@Lagartus, have you seen this already
https://docs.particle.io/faq/particle-tools/jtag/photon/#using-st-link-for-windows
But before reflashing your device, could you pull a dump file?
https://docs.particle.io/faq/particle-tools/jtag/photon/#saving-and-erasing-configuration
thanks for your help
its a photon
Are you using ST-LINK for Windows or openocd? I presume ST-LINK.
0x08000000 is the address for programming the boot loader, which is what you need to update for Dim D7.
0x08040000 is the address for the viewing configuration. You don’t need to change the settings (Address, Size and Data Width) as those are for viewing data, and you’re going to be programming it instead.
Instead you want to use the Program and Verify menu item in the Target menu. It’s the next picture in the FAQ.
Rick
Did start a fresh procedure
Followed instructions
Stopped here
Cannot disable read out protection
Please help @rickkas7
Thanks for your help
Its says that protected (option bytes)
The wierd thing is the photon was never connected , only usb
I will send it to be exchanged then
Thanks again for your time
