Quark
1
Hi Folks,
I’m trying to create a Webhook to transfer data from my Electron board to a RPi server, running TIG stack. I’m trying to follow this Tutorial:
https://docs.particle.io/tutorials/integrations/influxdata/
I try and create the webhook in the Console using mt RPi IP address, in the following format
http://<my_IP_address>:1619
But get the following error:
“Integration creation failed: url must use a valid protocol and not reference private hostnames”
Can anyone shed some light on the reason for this error? And what is the correct workaround to get a Webhook sending data to my Pi?
Is <my_IP_address>
a public address?
Quark
3
Good question, I’d not considered that, being new to all this.
No, I don’t think the IP address I’ve used is public. Reading this seems I can use this to find out my routers external IP address
curl icanhazip.com
Might need to configure my router too. I’ll see how I get on. Any other tips for setting up the webhook welcome though.Thanks.
Yes, you need to use the public address of your router and configure port forwarding to your RPi - after that you should be fine.
Quark
5
Right, I’ve made some nice progress but hit another setback.
I’ve created the Webhook in the particle console using the correct IP address:
Telegraf is setup to listen on port 1619, and seems to be running fine: ‘Started the webhooks service on :1619’.
I’ve configured by router for port forwarding on port 1619.
Logs in the particle console say Webhook triggered. Good news. But then gives
‘Error Status 404 from <my_IP_address>’
and ‘Sleeping, too many errors, please wait and try again’
Presume it can’t get a reply from my server.
Any thoughts most welcome.
Thanks.
system
Closed
6
