Hi, this is a very cool device…
So I am just setting up the basics for debugging and the serial port is outputting a bunch on factory messages instead of my app serial;
Here is a simple app and when I connect to the serial port from my mac or any serial app like Arduino Monitor I get factory stuff.
int count=0;
Serial.println("setup");
count++;
delay(1000);
Serial.println("loop" + count);
below is the output. Note that the flash form the cloud IDE works I get Magenta blinking and all the proper lights and reboot etc… it all looks good except no serial output except the following.
spark/cc3000-patch-version
c3000-patch-version
3000-patch-version
000-patch-version
00-patch-version
0-patch-version
-patch-version
patch-version
atch-version
tch-version
ch-version
h-version
-version
version
ersion
rsion
sion
ion
on
n
device.spark.io
evice.spark.io
vice.spark.io
ice.spark.io
ce.spark.io
e.spark.io
.spark.io
spark.io
park.io
ark.io
rk.io
k.io
.io
io
o
SSID:
SID:
ID:
D:
Security 0=unsecured, 1=WEP, 2=WPA, 3=WPA2:
WEP, 2=WPA, 3=WPA2:
EP, 2=WPA, 3=WPA2:
P, 2=WPA, 3=WPA2:
, 2=WPA, 3=WPA2:
2=WPA, 3=WPA2:
2=WPA, 3=WPA2:
=WPA, 3=WPA2:
WPA, 3=WPA2:
PA, 3=WPA2:
A, 3=WPA2:
, 3=WPA2:
3=WPA2:
3=WPA2:
=WPA2:
WPA2:
PA2:
A2:
2:
** Even though the CC3000 supposedly supports WEP,
sedly supports WEP,
edly supports WEP,
dly supports WEP,
ly supports WEP,
y supports WEP,
supports WEP,
supports WEP,
upports WEP,
pports WEP,
ports WEP,
orts WEP,
rts WEP,
ts WEP,
s WEP,
WEP,
WEP,
EP,
P,
** we at Spark have never seen it work.
never seen it work.
never seen it work.
ever seen it work.
ver seen it work.
er seen it work.
r seen it work.
seen it work.
seen it work.
een it work.
en it work.
n it work.
it work.
it work.
t work.
work.
work.
ork.
rk.
k.
** If you control the network, we recommend changing it to WPA2.
hanging it to WPA2.
anging it to WPA2.
nging it to WPA2.
ging it to WPA2.
ing it to WPA2.
ng it to WPA2.
g it to WPA2.
it to WPA2.
it to WPA2.
t to WPA2.
to WPA2.
to WPA2.
o WPA2.
WPA2.
WPA2.
PA2.
A2.
2.
The device is obviously suggesting some things but the network is WPA2 and the core is online in the cloud… so how do I get this guy to output my serial?
thnx
Neil
