Just a warning, latest Master does not connect to any of my wifi hotspots again after flashing.
The fix was to re do smart-config for the various hotspots.
Not sure what is the cause of this but just wanted to give a heads up as this was not an issue when upgrading previously.
(I am flashing using DFU if I explained badly)
Hi @Mike43110,
Thanks for the heads up! I was not aware of this side effect, but I know there has been work on fixing a wifi credentials clearing bug, I wonder if this is the cause? I’ll log a bug for this, and if it’s okay, I’d like to tweak the title accordingly:
from “Current Master-build does not connect to WiFi anymore” to “Current Master-build won’t connect to previously saved WiFi profiles anymore”
No problem!
It was quite frustrating initially as I had no idea what was going on, so I thought just giving some a heads up would be useful.
Do tell if you feel that I am not being constructive!
I did not encounter this after the flash but would be fun trying to replicate this!
I seem to not be able to recreate it anymore…
The only thing that I changed was the cc3300 driver, which I doubt would have affected it.
Previous to that, factory reset -> Connect and test connection -> DFU Flash and I couldn’t connect.
Oh well, while leaving me confused. I can’t replicate it anymore which is a good thing.
Hmm, do you mean you ran the cc3000 patch programmer to update the driver?
Please keep us posted if you see this again, and you’re definitely being constructive.
David
Yes, I ran the patch programmer
