Wanted to share some findings with trying to create stable firmware for the Core.
The bug: If a core can’t connect to a WiFi AP for a long period of time ( >24h ) it will stay disconnected even if the wifi AP becomes available again. After a reset the Core will connect again.
This is pretty bad for long-term stability, since every time a Core’s WiFi network goes down for some time, it will need a reset to be able to connect to any network again. I suspect it’s an issue with the CC3000.
To reproduce the issue:
- Power up a core and reset all wifi creds, and upload only one set of credentials.
- Remove the WiFi AP so the Core has nothing to connect to.
- After 24h put the WiFi AP back up.
- The Core will not be able to connect to the network.
The fix:
Cycling WiFi.off / WiFi.on or WiFi.disconnect / WiFi.connect seems to solve the issue. You can include this chunk of code in your main loop if you’re concerned about this issue.
static uint32_t wifi_ticks ;
if( WiFi.ready() == true ){
wifi_ticks = millis() ;
else{ /* Wifi is not connected */
if( 600000 < ( millis() - wifi_ticks )){
/* every 10 min when disconnected */
/* cycle the WiFi power / connection */
wifi_ticks = split_ticks ;
/* Option A : Toggle the disconnect/connect command */
WiFi.disconnect() ;
delay( 5000 ) ;
WiFi.connect() ;
/* Option B : Toggle power off/on wifi command */
WiFi.off() ;
delay( 10000 ) ;
WiFi.on() ;
delay( 2000 ) ;
WiFi.connect() ;
