Code that complied fine yesterday fails today
Code that has not changed now gets lots (27) compile errors.
I went back and tried the original example code (SimpleChat) I used as a starting point for my code and now it also fails.
What was changed last night?
Here are samples of the new errors from the SimpleChat example code for the RedBear Duo.
Link to example code: https://github.com/redbear/STM32-Arduino/tree/master/arduino/libraries/RedBear_Duo/examples/03.BLE/SimpleChat
You will need to comment out these lines as the Particle pre-processor does not like them.
//#if defined(ARDUINO)
//SYSTEM_MODE(SEMI_AUTOMATIC);
//#endif
simplechat.cpp:77:30: error: variable or field ‘deviceConnectedCallback’ declared void
void deviceConnectedCallback(BLEStatus_t status, uint16_t handle);
simplechat.cpp:77:59: error: expected primary-expression before 'handle’
simplechat.cpp:80:37: error: variable or field ‘characteristic2_notify’ declared void
static void characteristic2_notify(btstack_timer_source_t *ts);
I’m also having problems with code that compiled fine yesterday…
I wonder if your code is now compiling with system firmware 0.6.1… Can you check in the devices tab at https://build.particle.io
