Redbear Duo sendNotify Broken?
After many days of tinkering and debugging I’ve finally found a workaround but it doesn’t seem to be a proper solution.
Please refer to the logs I’ve posted here for my findings:
At the end of the day, I recently purchase the duo and I spent some time loading your samples onto it for BLEController and SimpleChat, both of which have problems when calling sendNotify.
With BLEController, it scans and finds the device and upon connection it doesn’t receive a response and disconnects.
With SimpleChat, on first run it can only receive one message from the duo. After that all other messages are discarded.
In both cases, the duo is still able to receive messages fine, while not being able to send.
After digging into the GitHub docs, I found that there was another send function sendIndicate which I converted all your sample code to using and the both started to work as expected.
I’m wondering if there is something inherently wrong with the base sendNotify function in the latest version of the firmware.
I looked up (and confirmed through experiencing it) that sendIndicate does not get as fast of a response and causes noticeable latency when sending large amounts of data as per the nature of indications. We want to use notifications at the end of the day.
Using the RedBear MiniBLE and the Shield, both send data fairly fast. Examples are not working for the duo.
Device: iPhone X
iOS: 11.4
Arduino RedBear Duo Board: v0.3.2
Firmware: v0.3.2
OS: OSX
Also have confirmed same problems on an Android phone.
Warren
Let me ping someone that might be able to help, @rickkas7 or @ParticleD are you able to assist?
