Newbie questions - thanks in advance.
I am trying to run a readbear duo as a ble beacon scanner. I am using the following code and it is compiling without any errors in the particle ide:
Questions:
it is not printing out any of the varibles ie; RSSI strength, SSID - into the console
it looks like its building some html - where do i go to see this page?
where is it getting the IP address from - how do i print the IP address?
after a couple of minutes it disconnects (goes flashing green) is there a timer disconnect code somewhere?
@emeraldmedia, this forum is for Particle devices and since you are using the Arduino IDE for programming your Duo, this question is best asked on the Redbear Duo forum.
