Code isn't flashing to boron
Hello,
I am struggling in flashing the code to boron, boron’s LED indicate that it’s in connected mode, but flashing the code give unsuccessfull flash and the flash/status =failed. So what’s your suggestion for this problem.
I am still new to mesh network and particle devices.
Thank you for your time.
Are you using WEBIDE or workbench?
if WebIDE, have you tried putting the Boron in safe mode?
https://docs.particle.io/tutorials/device-os/led/boron/#ota-firmware-update
perfect, Thank you it worked well
