Code flashing correctly, but status 'failed'
Hi guys,
Whenever I hit flash on the Web IDE, I get a spark/flash/status of failed. The updated code, however, seems to be flashed correctly and everything works as expected. Here’s the typical events I get while flashing:
event: spark/flash/status
data: {"data":"failed ","ttl":"60","published_at":"2016-02-08T14:08:22.202Z","coreid":"xxx"}
event: spark/status
data: {"data":"online","ttl":"60","published_at":"2016-02-08T14:08:22.199Z","coreid":"xxx"}
event: spark/device/app-hash
data: {"data":"B260284A56FF00B208C15C2A0E61EA71CCFED36BEA2F5167BC5BC7A055A76C3E","ttl":"60","published_at":"2016-02-08T14:08:28.346Z","coreid":"xxx"}
As far as I know, the app-hash event is only triggered after a flash, right? Any idea why I get this status of failed, even though the new code is flashed just fine?
Cheers,
Alex
You can ignore the failure message - it’s a false negative caused by the way the cloud determines the result of the OTA - the cloud team are aware of this - I’ve posted a suggestion internally to to give some time to fixing it this sprint.
Still happening, but for me it is intermittent instead of always. Sometimes it says success.
{"name":"spark/flash/status","data":"started ","ttl":"60","published_at":"2016-07-11T21:05:08.297Z","coreid":"2f0031000647343232363230"}
{"name":"spark/flash/status","data":"failed ","ttl":"60","published_at":"2016-07-11T21:05:12.569Z","coreid":"2f0031000647343232363230"}
{"name":"spark/status","data":"online","ttl":"60","published_at":"2016-07-11T21:05:12.566Z","coreid":"2f0031000647343232363230"}
{"name":"spark/device/app-hash","data":"B71CB519713E284D8CCFBA9B21D401F2F38E24D31AF9FD42BF2C18FD1477E3FD","ttl":"60","published_at":"2016-07-11T21:05:13.895Z","coreid":"2f0031000647343232363230"}
App hash is different, so I assume its actually success, like the IDE says
Is this still an issue? I am getting this message after every flash attempt. thanks.
data: {“data”:"failed ",“ttl”:60,“published_at”:“2018-12-07T05:07:54.060Z”,“coreid”:“4800000000000002”}
There are several reasons why a flash would fail with that error:
  • The device isn’t actually online (more common with cellular)
  • An Electron with a 3rd-party SIM card has the keep-alive set incorrectly
  • The user firmware is interfering with the flash.
The last one can usually be remedied by flashing in safe mode (breathing magenta). Hold down RESET and SETUP/MODE, release RESET and continue to hold down SETUP/MODE until the status LED blinks magenta (red and blue at the same time). Release SETUP/MODE. Wait while the status LED cycles trough blinking green, blinking cyan, fast blinking cyan, and finally breathing magenta. Then try flashing.
Thanks for the reply Rick. This one was the culprit
